New 2.8 Liter Six for the Racecar, I'll be asking a bunch of Conversion Questions |
motorvated |
Oct 21 2022, 03:28 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
The first question I have is related to modifications to the engine shelf pieces required for the 6-cylinder conversion. I noticed the Patrick Motorsports sells an expensive engine shelf kit for the 6-cylinder conversion. But, since the 6-cylinder is going into a Racecar, can I just cut out the entire engine shelf to maximize the available space in the engine compartment? Or, has anyone made a template that can be used to modify the 4-cylinder engine shelf to accommodate the 911 engines? I'd like just to remove the shelf parts if they are not needed. Thoughts on this? How do you other racers handle this. Many more questions to follow. I know there are many conversion threads out there, but it's hard to weed through them to see if they address the question(s) that I have. Plus most of Tigre are for street car conversions, not race cars.
Mike S. |
brant |
Nov 4 2022, 07:00 AM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I run a 901 instead of the 915
I ran my trans cooler with three different ducting (intake air) set ups all measured with a trans oil temp gauge The small electric fan out performed 2 different ram air set ups. Air flow under the rear trunk is restricted the lower the car is We put our trans cooler into the rear trunk I would want to actually measure the effectiveness of any set up Oiil coolers are all about intake and exits That’s why radiators are shrouded on production cars I ran the same front cooler on my old race car with 3 different exit designs and lowered the oil temp15 degrees each time I improved the exit You may benefit from copying effective race set ups of others Look at the fastest set ups. Frank beck for example there is a lot of ambient temp under the trunk... those exhaust headers are really hot and heating the whole area... heat tends to get trapped in that area too.... |
Lo-Fi Version | Time is now: 11th May 2024 - 07:24 PM |
