914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,188 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I am working with a company to develop new EV14 injectors that will work for 2.0L engines. They already have the setup made just not the correct injector. Sending NOS injectors for them to evaluate so they can finish kit. Stole picture to show design elements. Silver adapters have been eliminated and new grooved O rings fitted, along with new rail design. Just an idea of set up.
Projected cost under $500. Attached image(s) ![]() |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,219 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
I am working with a company to develop new EV14 injectors that will work for 2.0L engines. They already have the setup made just not the correct injector. Sending NOS injectors for them to evaluate so they can finish kit. (IMG:style_emoticons/default/idea.gif) interesting. Always impressed with the ingenuity of the community to come up with solutions to the NLA parts situation! (IMG:style_emoticons/default/aktion035.gif) Can’t wait to see the finished product! |
914Sixer |
Found a picture to show design elements.
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,379 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
Check this place;
https://www.cjponyparts.com/catalogsearch/r...t/?q=+injectors I know a couple people are using injectors from them. |
sithot |
Member ![]() ![]() Group: Members Posts: 448 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None ![]() ![]() |
Check this place; https://www.cjponyparts.com/catalogsearch/r...t/?q=+injectors I know a couple people are using injectors from them. Cool! Which ones? Chevy, Ford or Jeep based? (IMG:style_emoticons/default/popcorn[1].gif) Seriously. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,031 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I am working with a company to develop new EV14 injectors that will work for 2.0L engines. They already have the setup made just not the correct injector. Sending NOS injectors for them to evaluate so they can finish kit. Stole picture to show design elements. Silver adapters have been eliminated and new grooved O rings fitted, along with new rail design. Just an idea of set up. Projected cost under $500. @914sixer You may have a interference problem on the passenger side to the MAP sensor. I know the fuel rail with the test port will hit the NAP sensor. What advantage will these have over the SMP injectors that are available for 2.0s ? |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I am working with a company to develop new EV14 injectors that will work for 2.0L engines. They already have the setup made just not the correct injector. Sending NOS injectors for them to evaluate so they can finish kit. Stole picture to show design elements. Silver adapters have been eliminated and new grooved O rings fitted, along with new rail design. Just an idea of set up. Projected cost under $500. D-jet compatible injectors or not this would still be beneficial for anyone running aftermarket injection as the selection of new high impedance injectors that are compatible with the stock 914 fuel rails is really REALLY small. If you produce these I would be in for a set, if not multiple sets. |
JamesM |
I am working with a company to develop new EV14 injectors that will work for 2.0L engines. They already have the setup made just not the correct injector. Sending NOS injectors for them to evaluate so they can finish kit. Stole picture to show design elements. Silver adapters have been eliminated and new grooved O rings fitted, along with new rail design. Just an idea of set up. Projected cost under $500. @914sixer You may have a interference problem on the passenger side to the MAP sensor. I know the fuel rail with the test port will hit the NAP sensor. What advantage will these have over the SMP injectors that are available for 2.0s ? I think the angle of the picture is deceiving. The fuel rail port hits the MPS because the injector hoses turn up 90 degrees, this setup looks to be straight out from the injector ports so may not be an issue. |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,002 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Very attractive setup. Looks like it would remove all the difficult angle and seal issues with the old design and the cranky rails.
NARP74 |
Check this place; https://www.cjponyparts.com/catalogsearch/r...t/?q=+injectors I know a couple people are using injectors from them. Cool! Which ones? Chevy, Ford or Jeep based? (IMG:style_emoticons/default/popcorn[1].gif) Seriously. Start with @IanKarr , he has mentioned them in a video or 2. |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 732 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
That foto looks like the Injector-Rehab system currently being sold for VW Bay Window Buses, VW Vanagons, and Porsche 914s. Here is the link:https://injector-rehab.com/product/complete-fuel-rail-system-for-type-4-vw-bus-injectors-included/
Lo-Fi Version | Time is now: 8th July 2025 - 10:42 AM |
