3.2 in a 914, CHT times 2? |
NARP74 |
Oct 29 2022, 09:04 AM
Senior Member Group: Members Posts: 1,065 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
The car I bought a little while ago had a 3.2 in it with stock FI and engine mgmt. That includes a CHT for the computer. At the last minute, the selling agent I was buying the car from decided to put in a center console with a CHT gauge. He did not have anything to drive the gauge so they hooked up a real fast solution just to get the gauge running. See the pic...
The problem is that where and how it is located, it pretty much just reads 0 or 350, nothing else. It never reads lower, never cools off. It is right by the exhaust manifold. The 3.2 has a built in CHT. Can I buy a new temp ring and tie it in under the factory CHT on cyl 3 like the factory? Is there room under the plugs on a 3.2 for the CHT ring like it would be hooked up on a 4 cyl? I have not looked into the plug area to see if there is any room. I don't think I can split the output of the factory CHT or it will change the resistance, I am guessing. What have others done to feed a CHT gauge on a 3.2? |
NARP74 |
Oct 29 2022, 11:33 AM
Pretty sure the factory put the original in the block by #3. I'll take a look at the plug situation and go down that road. Maybe some temp measurements will point me in the right direction.
Lo-Fi Version | Time is now: 17th May 2024 - 09:19 PM |
