311905301 trigger points, having 25 sets rebuilt preorder |
dr914@autoatlanta.com |
Nov 3 2022, 04:10 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I am having 25 sets of fuel injection trigger points rebuilt to the highest standards with teflon blocks. They will be calibrated and ready to install. If you would like to pre order a set of them Please do so here:
http://www.autoatlanta.com/Porsche-914-Dis...B311905301.html. You will not be charged until the package is on the dock with a tracking number. They will be ready in a month. These have been long sought after, and would have been very very expensive to get made (I checked!). No d jetronic 914 will run well without a good set installed |
JeffBowlsby |
Nov 3 2022, 05:21 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
To clarify these are rebuilt, so you need the core charge up front and the actual core to rebuild?
What work is done/parts replaced to rebuild? Thanks for supporting the 914 and Djet! @dr914@autoatlanta.com |
Nov 4 2022, 02:50 PM
We have many many many sets in stock that were now sent off to be rebuilt. We only charge a core to make sure we get a rebuildable set back NO NEED to send yours in advance. the blocks are replaced with teflon the unit is ultrasonically cleaned and calibrated
To clarify these are rebuilt, so you need the core charge up front and the actual core to rebuild? What work is done/parts replaced to rebuild? Thanks for supporting the 914 and Djet! @dr914@autoatlanta.com |
Lo-Fi Version | Time is now: 8th June 2024 - 07:39 PM |
