WTB: Parts for a 1.7 build |
saigon71 |
Nov 28 2022, 09:09 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm building a 1.7 engine this winter and figured I'd check here for parts before buying brand new.
I'm in search of the following: 1. Main, rod & 2 sets of cam bearings - all standard 2. CB Performance Model 3082 intake manifolds for Weber 34ict (these are the taller ones with balance tube outlets). 3. CSP belcrank or cable throttle linkage for Weber 34ict 4. 90MM piston rings - standard 5. Weber 34ICT jet pack (701-ICT) 6. Lightened flywheel 7. Camshaft, lifters & cam gear: Engle FK65/FK7, Webcam 86A or European Motorworks 054-106-E 8. Performance valve springs - single spring 9. 1.7L gasket set 10. Front & rear main seals 11. 8 & 9 MM valve guide drivers |
saigon71 |
Dec 2 2022, 10:28 AM
Th3wolf |
Dec 4 2022, 07:31 AM
Daveteevee Group: Members Posts: 3 Joined: 13-March 21 From: PA Member No.: 25,319 Region Association: North East States |
I have my complete 1.7 with D Jet sitting in my garage. Ran fine when I removed it in June. Let me know if you’re interested.
Lo-Fi Version | Time is now: 5th May 2024 - 12:06 PM |
