Fuel Line Routing with Dual Carbs, Fuel Lines |
NS914 |
Nov 30 2022, 02:33 PM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Hi Guys,
I have been searching a bit this afternoon trying to find some nice images re How you have routed fuel lines, particularly through the rear fire wall and up to the carbs. Could I have a few of you take some pics of both how you routed the lines and also how you fixed them in place re along the fire wall etc. Truly, thank you for the 100th time for helping me out. Regards, Grant |
simonjb |
Nov 30 2022, 07:31 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
simonjb |
Nov 30 2022, 07:33 PM
ChrisFoley |
Dec 1 2022, 04:56 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Interesting how you set up the carbs Simon. I've always aimed the inlet fittings on carbs to the rear, but what you've done is nicely organized and keeps the hoses out of the way.
NS914 |
Dec 1 2022, 07:42 AM
Simon, really nice set up and you solidified my thoughts about a Pressure Regulator. those pics below are great. I had not thought of that routing so really glad you displayed that.
I knew I could count on our community! thanks again. Grant |
simonjb |
Dec 1 2022, 08:17 AM
Thanks guys - I learned it from this site as well! And I recall I have Tangerine components - aka the best !
friethmiller |
Dec 1 2022, 08:47 AM
Member Group: Members Posts: 468 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I'm using Tangerine's fuel pump/filter/lines, as well. I really like Simon's setup. It makes mine look like crap (IMG:style_emoticons/default/biggrin.gif). Though I did have to deal with the heim rod brace in routing the fuel hose. I drove this through-out the summer in Texas and never had any issues with vapor-lock.
NARP74 |
Dec 1 2022, 09:43 AM
Senior Member Group: Members Posts: 1,060 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
That filter pump combo is available several places, it says don't separate the two or it will void the warranty. I wonder why? I do like that it solved the placement issues by doing it though.
NS914 |
Dec 1 2022, 09:55 AM
Such a Clean Car and thanks for posting.
Regards, Grant |
friethmiller |
Dec 1 2022, 09:58 AM
Chris,
My carbs feed from the the front as well but that's only because I decided to flip them to put the throttle wheels to the back. There's just too much in the way to get a straight shot for the slave cable. My fuel line still routes from the rear and into a tee that splits in equal length lines to each carb. I pulled the Tee out a bit here for the photo. Just noticed I used the wrong type of clamp going into the Tee. Damn! Add that to my To-Do list (IMG:style_emoticons/default/biggrin.gif) Hope all this helps, Grant. |
ndfrigi |
Dec 1 2022, 10:05 AM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
NARP74 |
Dec 1 2022, 10:13 AM
simonjb |
Dec 1 2022, 01:16 PM
NS914 |
Dec 2 2022, 05:30 AM
Just reviewing again...my god you guys build beautiful cars....I have a lot of work to do if I want to come even close to your cars....just Wow! thanks again.
NS914 |
Dec 2 2022, 05:32 AM
Chris, My carbs feed from the the front as well but that's only because I decided to flip them to put the throttle wheels to the back. There's just too much in the way to get a straight shot for the slave cable. My fuel line still routes from the rear and into a tee that splits in equal length lines to each carb. I pulled the Tee out a bit here for the photo. Just noticed I used the wrong type of clamp going into the Tee. Damn! Add that to my To-Do list (IMG:style_emoticons/default/biggrin.gif) Hope all this helps, Grant. Chris, this really does....thank you for making the time to post! |
Lo-Fi Version | Time is now: 7th May 2024 - 12:34 PM |
