Restoring Heater Control Flap, Painting |
Deusexmachina77 |
Dec 1 2022, 02:13 PM
Member Group: Members Posts: 89 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
I am trying to reinstall my heater. I think I have all the parts that were removed by the PO. I stripped the rust using Evaporust (which worked incredibly well, BTW). Now I need to paint the heat control flaps. Is it okay to paint the inside, or will I send burning fumes into my interior?
I'm planning on using heat-resistant paint. Any recommendations? Thanks, Victor Attached thumbnail(s) |
914werke |
Dec 1 2022, 02:28 PM
"I got blisters on me fingers" Group: Members Posts: 10,034 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yes dont use any paint on the inside. I treat the outside once de-rusted then blast & powder coat them.
I assume you checked to ensure the seal material was in good shape prior, otherwise it will still work just not as well. |
Deusexmachina77 |
Dec 1 2022, 05:20 PM
The inside pads look okay to me. That's why I thought the inside should not be painted.
Thank you! |
914Sixer |
Dec 1 2022, 09:32 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I used high temp black grill paint.
roundtwo |
Dec 3 2022, 12:49 AM
Member Group: Members Posts: 269 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Is there a way to replace the material inside that creates the seal when they are closed?
FlacaProductions |
Dec 3 2022, 06:03 AM
Senior Member Group: Members Posts: 1,568 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@bbrock has done it but i can't find the thread...
Garland |
Dec 3 2022, 08:18 AM
Restoration Fanatic Group: Members Posts: 1,328 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
FlacaProductions |
Dec 3 2022, 10:26 AM
That's the one I was thinking of...
Lo-Fi Version | Time is now: 2nd May 2024 - 03:11 PM |
