can you polish a windshield? |
Olympic 914 |
Dec 1 2022, 06:56 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
My windshield has some wear from the wipers. but no cracks
Can this be polished? or is there some coating that would be ruined (more) by trying. When I did the car I left the windshield in, and really have no reason to change it out now. But I would like to eliminate some of the fine scratches from years of wear. |
Mikey914 |
Dec 3 2022, 02:41 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Lexan is just a trade name for acrylic. You can polish acrylic using wet sand paper and the 3M perfect-it system.
Start with the least grit needed (600 hopefully, or higher), then wipe clean, go to 1200, then 2000. After you can use the perfect it system. I've done this on the WAS tops and on aircraft I've owned. |
burton73 |
Dec 3 2022, 05:34 PM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Lexan is just a trade name for acrylic. You can polish acrylic using wet sand paper and the 3M perfect-it system. Start with the least grit needed (600 hopefully, or higher), then wipe clean, go to 1200, then 2000. After you can use the perfect it system. I've done this on the WAS tops and on aircraft I've owned. Sheet grade polycarbonate (aka Lexan or Makrolon) and acrylic sheet (aka Lucite) are two of the most frequently used see-through plastics. Each of the two have benefits and drawbacks. Acrylic is shinier and polycarb is stronger. Acrylic is less expensive but easier to crack.Oct 12, 2022 Lexan is more flexible is used on motorcycle windshields. I use it around the deck of my jacuzzi as Acrylic is much easier to crack. As far as polishing goes pretty similar you got to go through the sanding grits and then you got to buff it with a wheel or a non-directional sander. Different grits of compound so you get the desired effect. New compounds from people like the Chemical Guys really help with this job. Bob B |
Lo-Fi Version | Time is now: 9th May 2024 - 12:24 AM |
