2 Pages V < 1 2
> can you polish a windshield?
930cabman
post Dec 2 2022, 02:13 PM
Post #21
QUOTE(Aerostatwv @ Dec 2 2022, 02:57 PM) *
There seems to be a lot of YouTube videos that may show you what's out there and how it's done. Looks like the key thing is to go slow and keep it cool.
Sure, there are several different polishes and/or methods, but there is nothing like a new windscreen. I am very open to a process for polishing but in my 50+ years in the biz, I still have yet to find an acceptable means. What is your time worth?
fixer34
post Dec 2 2022, 07:21 PM
Post #22
Following this, been asking myself the same question for years. Original windshield on my -6 seems to be smooth, but when the sunlight hits it just right, it almost goes translucent. So begs the discussion about replace with aftermarket new (and clean/clear) or try to revive original equipment on a numbers matching car.
Ishley
post Dec 2 2022, 10:58 PM
Post #23
Ian Karr uses something on one of his YouTube videos and it looked great. You should be able to make it better.
Mikey914
post Dec 3 2022, 02:08 AM
Post #24
The rubber man
QUOTE(fixer34 @ Dec 2 2022, 05:21 PM) *
The question here is, why? The windshields are laminated together, if the center layer is why, then no amount of polishing will help. If it's a fine pitting from the glass being abraded over time you have a shot.
dhuckabay
post Dec 3 2022, 04:31 AM
Post #25
QUOTE(g911 @ Dec 1 2022, 06:24 PM) *
Anything for lexan windshields showing scratches?
Have a cleaner polish for my planes window, bought it from Spruce Supply. Works well on Lexan.
Mikey914
post Dec 3 2022, 02:41 PM
Post #26
The rubber man
Lexan is just a trade name for acrylic. You can polish acrylic using wet sand paper and the 3M perfect-it system.
Start with the least grit needed (600 hopefully, or higher), then wipe clean, go to 1200, then 2000.
After you can use the perfect it system. I've done this on the WAS tops and on aircraft I've owned.
930cabman
post Dec 3 2022, 04:15 PM
Post #27
QUOTE(Mikey914 @ Dec 3 2022, 03:41 PM) *
Lexan is a product of GE and is a polycarbonate NOT an acrylic.
Many of us with ageing vision have a difficult time with night vision, rain, depth. Why would anyone cheap out with their windscreen.
One answer: new windscreen
Mikey914
post Dec 3 2022, 05:22 PM
Post #28
The rubber man
Then the windows were not Lexan. Polycarb is definitely a different animal.
burton73
post Dec 3 2022, 05:34 PM
Post #29
Senior member, and old dude
QUOTE(Mikey914 @ Dec 3 2022, 12:41 PM) *
Sheet grade polycarbonate (aka Lexan or Makrolon) and acrylic sheet (aka Lucite) are two of the most frequently used see-through plastics. Each of the two have benefits and drawbacks. Acrylic is shinier and polycarb is stronger. Acrylic is less expensive but easier to crack.Oct 12, 2022
Lexan is more flexible is used on motorcycle windshields. I use it around the deck of my jacuzzi as Acrylic is much easier to crack. As far as polishing goes pretty similar you got to go through the sanding grits and then you got to buff it with a wheel or a non-directional sander. Different grits of compound so you get the desired effect. New compounds from people like the Chemical Guys really help with this job.
Bob B
relentless
post Dec 3 2022, 05:48 PM
Post #30
There is nothing like a clean, fresh windshield. Especially after 50 years of sand blasting! Back in the day we used Cerium Oxide, but polish too long and you ended up with distortions in vision. Not good. Don't cheap out, these cars are becoming too valuable to cut corners. Evaluate whether your windshield can have water spots removed (doable) or whether the damage is permanent.
930cabman
post Dec 3 2022, 05:55 PM
Post #31
QUOTE(relentless @ Dec 3 2022, 06:48 PM) *
Exactly, I like a fresh windscreen in my DD and have changed them 4-5 years just because, seeing clearly is good
Olympic 914
post Dec 16 2022, 09:25 AM
Post #32
Decided to work on this yesterday,
Promised report.
Here’s what’s in the Eastwood package
First I laid some plastic drop cloths over the car to protect from compound getting everywhere
You can see the wiper marks here reflected in the light.
I only used two teaspoons of compound mixed with a sprits of water to mix it up (they recommend a toothpaste like thickness, mine was thinner)
Started out with their pad mounted in a cordless drill, they recommend a speed of 600-1500 rpm max
Well my dual range drill goes 0-450 or 0-1800. So I put it on the lower range to start.
Very hard keeping the 3” pad they supplied flat on the surface, It would start to oscillate violently at 450 and you had to stop and start again. In the top range anywhere near the 1500 it was slinging compound all over everything, So I stayed with the lower range.
When the instructions say “Labor intensive” They are not kidding.
I worked the windshield for 3 hours doing ¼ at a time, spritzing with water to keep the surface wet (but not running) wiping off every 15-20 min to check progress.
And change batteries, (Had two on charge all the time)
After around 3 hours I stopped for lunch and thought about this for a while.
Then I decided to get out my Porter Cable Orbital buffer and try that out.
I had originally not used it because the min speed was 2400 OPM and I thought it would be too fast.
Found that a Meguires 6” cutting pad seemed to be similar to the 3” wool or felt pad supplied by Eastwood.
So I hooked up the 6” pad and started again.
MUCH much easier to control, and I could do ½ the windshield at a time. The larger pad didn’t want to lift an edge like the smaller pad, Kept it moving to avoid heating up one spot.
So I worked this for about another 3 ½ hours and I am quite happy with the results.
If I get the light Just right I can still see where the wiper marks were, BUT they are almost invisible.
A drive at night with lights coming towards me will be the real test.
Hoping for the best.
I only used two teaspoons of compound mixed with water out of the ½ lb supplied in the kit.
You could do this many times with this much compound.
With this compound you don't have to worry about cutting too much, It takes a long time so it must be pretty fine.
I struggled with the 3" pad on a drill, Maybe on orbital buffer it would have been OK but the 6" pad was much easier to control
Hope this helps someone who wants to tackle this project.
StarBear
post Dec 16 2022, 09:57 AM
Post #33
Soooo helpful. Encourages me to initiate effort after New Years. Great idea with the plastic; wouldn’t have thought of that. Maybe more like 90 minute sessions for me, though.
Thanks!
bbrock
post Dec 16 2022, 01:53 PM
Post #34
Just seeing this thread. I've polished (actually ground) out some pretty serious scratches and on side glass to boot. Everybody says it can't be done until somebody does it. Then they still say it can't be done. (IMG:style_emoticons/default/av-943.gif)
It was not easy, but I was able to salvage a set of tinted side glass. Here's how I did it:
http://www.914world.com/bbs2/index.php?s=&...t&p=2790699
Dion
post Dec 17 2022, 09:42 PM
Post #35
RN
Looks great Tom! Yes, I remember now how messy a process it was and quite the time consumer. Well done.
rgalla9146
post Dec 18 2022, 04:28 AM
Post #36
My experience was with a basic kit that provider no results after a few hours effort.
I have scratched tinted side glass too......
Brents results give me hope.
Excellent job.
Rory
StarBear
post Mar 3 2023, 03:34 PM
Post #37
Whew! Taking winter weather episode to do this in the garage. Both in-progress and done pics below.
Thanks to @olympic 914 for encouragement, advice, and just the right amount of little white powder!
No dramatic wow results as was in fairly good shape before, but got rid of little divots, light scratches, and wiper wear area on a 48-year old face. I should be so lucky!
About 6-7 hours of polishing. Do use the 6” pad and sufficient orbital polisher; can’t imagine doing it with a 3” one.
@rgalla9146 Do it! (IMG:style_emoticons/default/biggrin.gif)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 21st September 2026 - 02:59 PM
