Structural Question, crossmember bolts in sheer or tension? |
cooler |
Dec 2 2022, 06:28 PM
"Very Interesting!" Group: Members Posts: 31 Joined: 6-December 11 From: British Columbia Member No.: 13,865 Region Association: Canada |
hello 914 structural experts,
I am planning to create a new crossmember to stiffen rear suspension and support engine. The 914 rear suspension console is well known to flex under racing stress and was reinforced by factory racing teams. I intend to address the flexing issue and create engine (Audi V8) mounting locations with a new crossmember and diagonal tension members. The attached photo shows the location of crossmember (red) and diagonal tension members (blue). The crossmember spans between the suspension consoles, on center with the trailing arm pivot axis. The diagonal tension members span also from rear suspension consoles to firewall, near center tunnel. This assembly will need to be removable to facilitate engine removal and is intended to stiffen the entire engine bay/rear suspension. I am struggling with detailing the crossmember bolted connections at suspension consoles. I assume each connections should include two bolts each but, should the bolts be loaded in shear or in tension? What size should the bolts be? Thanks in advance |
Charles Freeborn |
Dec 3 2022, 09:39 AM
Member Group: Members Posts: 250 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
hello 914 structural experts, I am planning to create a new crossmember to stiffen rear suspension and support engine. The 914 rear suspension console is well known to flex under racing stress and was reinforced by factory racing teams. I intend to address the flexing issue and create engine (Audi V8) mounting locations with a new crossmember and diagonal tension members. The attached photo shows the location of crossmember (red) and diagonal tension members (blue). The crossmember spans between the suspension consoles, on center with the trailing arm pivot axis. The diagonal tension members span also from rear suspension consoles to firewall, near center tunnel. This assembly will need to be removable to facilitate engine removal and is intended to stiffen the entire engine bay/rear suspension. I am struggling with detailing the crossmember bolted connections at suspension consoles. I assume each connections should include two bolts each but, should the bolts be loaded in shear or in tension? What size should the bolts be? Thanks in advance Wow. An Audi V8 in a 914 sounds like a barrel of fun! AS for your crossmember questions I'd say make the flanges on the ends of the tubing somewhere in the 3/16" thick range (3mm?) and try to use 4 bolts per flange. Weld the flanges to the chassis with weld nuts pre-attached. I'd use a minimum of 4/8mm bolts per, 10.9 hardness minimum. As for the shear / tension question, the fastener choice (hardness) is the mitigating factor. |
stownsen914 |
Dec 3 2022, 11:55 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
You're correct to reinforce this area of the car, it can use it. As for whether to orient the bolts in tension vs. shear, it's an interesting question. If it were me, I'd do whichever is more convenient from a fabrication standpoint. A tension fastening arrangement might be easier at the firewall end (if I'm envisioning it correctly), and in shear at the suspension console end. I've seen supports made for this purpose, using rod ends. I imagine it's helpful to give any support you can in this area, but I'd prefer a solid attachment to counteract twisting forces. With the rod end arrangement, you get resistance to tension and compression forces but no resistance to twisting.
Lo-Fi Version | Time is now: 21st May 2024 - 03:43 PM |
