Structural Question, crossmember bolts in sheer or tension? |
cooler |
Dec 2 2022, 06:28 PM
"Very Interesting!" Group: Members Posts: 31 Joined: 6-December 11 From: British Columbia Member No.: 13,865 Region Association: Canada |
hello 914 structural experts,
I am planning to create a new crossmember to stiffen rear suspension and support engine. The 914 rear suspension console is well known to flex under racing stress and was reinforced by factory racing teams. I intend to address the flexing issue and create engine (Audi V8) mounting locations with a new crossmember and diagonal tension members. The attached photo shows the location of crossmember (red) and diagonal tension members (blue). The crossmember spans between the suspension consoles, on center with the trailing arm pivot axis. The diagonal tension members span also from rear suspension consoles to firewall, near center tunnel. This assembly will need to be removable to facilitate engine removal and is intended to stiffen the entire engine bay/rear suspension. I am struggling with detailing the crossmember bolted connections at suspension consoles. I assume each connections should include two bolts each but, should the bolts be loaded in shear or in tension? What size should the bolts be? Thanks in advance |
cooler |
Dec 10 2022, 06:47 PM
Charles Freeborn |
Dec 11 2022, 11:19 AM
Member Group: Members Posts: 250 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 21st May 2024 - 11:27 AM |
