| live free & drive |
Dec 10 2022, 05:41 PM
Member ![]() ![]() Group: Members Posts: 211 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None
Here is a good thread from 914Dave about his "bolt action" shifter:
http://www.914world.com/bbs2/index.php?sho...162451&st=0 |
| Steve |
Dec 10 2022, 06:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,025 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Here is a good thread from 914Dave about his "bolt action" shifter: http://www.914world.com/bbs2/index.php?sho...162451&st=0 Wow!! That thread is over ten years old. With everything available over the counter now, what is advantage of fabricating it yourself? I am jealous of such skills and equipment, but it would be interesting to feel a side by side comparison. Maybe a future WCR or other event. |
| mepstein |
Dec 10 2022, 07:38 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,534 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Here is a good thread from 914Dave about his "bolt action" shifter: http://www.914world.com/bbs2/index.php?sho...162451&st=0 I’ve never read that thread but Dave has taken me through a lot of the special features of his car. Any one of them blow me away. For instance, not realizing the 914-6 used a longer wire to the heat flapper boxes, they came up short. So Dave machined some extender brackets out of titanium to make up the difference. And then there’s the custom made fire suppression system. It’s all really amazing. @914Dave |
| rgalla9146 |
Dec 10 2022, 08:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,943 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Here is a good thread from 914Dave about his "bolt action" shifter: http://www.914world.com/bbs2/index.php?sho...162451&st=0 I’ve never read that thread but Dave has taken me through a lot of the special features of his car. Any one of them blow me away. For instance, not realizing the 914-6 used a longer wire to the heat flapper boxes, they came up short. So Dave machined some extender brackets out of titanium to make up the difference. And then there’s the custom made fire suppression system. It’s all really amazing. @914Dave (IMG:style_emoticons/default/agree.gif) I never saw that thread before tonight. I purchased the Bott kit in 2013 and worked on the trans, shift linkage and clutch linkage while doing my GT project. I had contact with Dave over the years but had no idea he was fabricating his own shift tower. Among other great feats. My set-up uses all stock parts except for the shift rod below the engine. I shifts OK but could certainly be better. I'm hoping that when I get back to it I can make it smoother and decrease the throw. Fantastic work Dave. Beautiful. Can't believe it's been almost ten years. |
| Steve |
Dec 11 2022, 01:08 PM
Here is a good thread from 914Dave about his "bolt action" shifter: http://www.914world.com/bbs2/index.php?sho...162451&st=0 I’ve never read that thread but Dave has taken me through a lot of the special features of his car. Any one of them blow me away. For instance, not realizing the 914-6 used a longer wire to the heat flapper boxes, they came up short. So Dave machined some extender brackets out of titanium to make up the difference. And then there’s the custom made fire suppression system. It’s all really amazing. @914Dave I ran into the same problem early on with my 914-6 factory heat exchangers. Bug pack/Empi sells short throttle cable extenders that work perfect for this application. 914 rubber also sells the correct length cables. https://914rubber.com/heater-lever-control-cable-for-914-6 |
| Dave_Darling |
Dec 11 2022, 04:49 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
So, How do you "flip" the ring gear ?? Do you replace the pinion shaft (gear) ?? No need to replace any of the major parts. You literally pull out the pinion shaft, grab the ring gear and associated bits, and run them around so they are on the other side of the pinion gear. In the pic I posted, just imagine the "differential carrier/ring gear" part flipped around so that what was toward the top of the image is now toward the bottom of the image, and what was toward the bottom of the image is now toward the top. Of course, there has to be room for the assembly on the other side of the housing that it lives in. And that's where some of the work comes in, because some trans designs don't really have room for it that way. --DD |
| 6er |
Dec 12 2022, 05:50 PM
Newbie ![]() Group: Members Posts: 7 Joined: 2-November 17 From: Los Angeles Member No.: 21,563 Region Association: Southern California |
lots of info
| 914dave |
Dec 13 2022, 01:00 PM
914 Addict ![]() ![]() ![]() Group: Members Posts: 740 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States
I cant believe its been ten years since i did the trans work. I will say that the shifter and trans operate smooth and reliable. I have around 17K on the setup now. Worth the effort. I was fortunate enough to find a Vellios kit cheap and by dumb luck. That made the decision easy to forward with the 915.
| CCSmith58 |
Dec 14 2022, 12:51 PM
Newbie ![]() Group: Members Posts: 12 Joined: 17-March 22 From: Southern California Member No.: 26,404 Region Association: Southern California
So, How do you "flip" the ring gear ?? Do you replace the pinion shaft (gear) ?? No need to replace any of the major parts. You literally pull out the pinion shaft, grab the ring gear and associated bits, and run them around so they are on the other side of the pinion gear. In the pic I posted, just imagine the "differential carrier/ring gear" part flipped around so that what was toward the top of the image is now toward the bottom of the image, and what was toward the bottom of the image is now toward the top. Of course, there has to be room for the assembly on the other side of the housing that it lives in. And that's where some of the work comes in, because some trans designs don't really have room for it that way. --DD Hey DD. THANKS... this is helping me understand. So... the ring gear + diff + bearings are "symmetrical" from the pinion centerline?? would any brand LSD work ?? |
Lo-Fi Version | Time is now: 12th March 2026 - 04:00 PM |
