Weber carb return line, where is the T |
Type 47 |
Dec 8 2022, 03:53 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
GregAmy |
Dec 8 2022, 04:57 PM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
You will need to change to a return-type fuel pressure regulator, otherwise pressure would be almost zero as it flowed right back into the tank (easiest path).
The return will be on the bypass side of the pressure regulator. Edit: something like this should work, mounted before the feed lines to the carbs: https://www.holley.com/products/fuel_system...rs/parts/12-887 Kinda curious: why? Worried about vapor lock? You're still going to have that last bit of feed to the carbs that will not be full flow, and that's the most-common locations for vapor lock. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:55 AM |
