74 left warm air guide differences?, What are they? |
FlacaProductions |
Dec 10 2022, 09:17 PM
Senior Member Group: Members Posts: 1,584 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I got this one but it is not correct/does not fit my 74 2.0
What is the correct part? (left/drivers side) Thank you! B |
914werke |
Dec 10 2022, 10:08 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
There is an early a mid & late
The early curved under the tailshift rod The Mid curved over the sideshift rod & the late is completely different than pictured to attach to the late HE's |
bdstone914 |
Dec 10 2022, 11:15 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
FlacaProductions |
Dec 11 2022, 07:49 AM
only fits one way, right? Not sure how you can install in INcorrectly but if anyone can, I'm sure it's me! i'll give it another look.
rhodyguy |
Dec 11 2022, 01:04 PM
The mounting holes align with the holes on the HEs and the case. Curve up.
FlacaProductions |
Dec 13 2022, 09:48 AM
Took a closer look - mine just needs some messaging and possible trimming. I guess I thought these would be plug and play but after thinking about it, after 50 years of getting moved around, it figures that a newly produced one might need a little help getting into place.
dax1969 |
Dec 14 2022, 08:00 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Looks ok. Just did mine (also a 74 2.0).
Passengerside is a replica, drivers side is an original I found krgds DAx |
dr914@autoatlanta.com |
Dec 14 2022, 09:27 AM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
there are three left ones. 70-72 with a downward hump front to rear, 73-73 with an upward hump to clear the late shifter, and 75 76 completely different for the emissions heat exchangers
I got this one but it is not correct/does not fit my 74 2.0 What is the correct part? (left/drivers side) Thank you! B |
914werke |
Dec 14 2022, 11:22 AM
FlacaProductions |
Jan 2 2023, 01:21 PM
there are three left ones. 70-72 with a downward hump front to rear, 73-73 with an upward hump to clear the late shifter, and 75 76 completely different for the emissions heat exchangers I got this one but it is not correct/does not fit my 74 2.0 What is the correct part? (left/drivers side) Thank you! B OK, George - so which one is your part number B022119356A? That's the one I ordered but it doesn't fit - it's kinda close but not really. Will need some massaging and trimming to make work. Wondering if I'm better off with a used/OEM one? I'm replacing one that is a bit rough so I know one fits - not just adding one. |
Lo-Fi Version | Time is now: 15th May 2024 - 09:59 AM |
