Jack Stand Police, WOW! Did you know this; I didn't. See post #30 |
76-914 |
Jan 5 2023, 10:49 AM
Superhawk996 |
Jan 5 2023, 11:02 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Moral of the story - use them improperly, your risk of getting hurt goes up. Same as any other tool.
windforfun |
Jan 5 2023, 11:31 AM
Senior Member Group: Members Posts: 1,789 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Thanks for posting this!!!
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
Root_Werks |
Jan 5 2023, 12:50 PM
Village Idiot Group: Members Posts: 8,320 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That was really interesting, thanks for posting!
I don't use ratchet stands. Pin type only. I've always been a little annoyed because they have a large base and get in the way. Now I'm glad they are given how easy some of the smaller based stands tipped over! 170lbs can easily be the weight of a person walking up and leaning up against your car. "Whatcha working on....oops!" |
76-914 |
Jan 5 2023, 01:15 PM
That was really interesting, thanks for posting! I don't use ratchet stands. Pin type only. I've always been a little annoyed because they have a large base and get in the way. Now I'm glad they are given how easy some of the smaller based stands tipped over! 170lbs can easily be the weight of a person walking up and leaning up against your car. "Whatcha working on....oops!" Or your wife driving into the back of your 914 when you're under it. Ask me how I know! (IMG:style_emoticons/default/shades.gif) |
76-914 |
Jan 5 2023, 01:18 PM
Thanks for posting this!!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) This guy has the personality of a Fire Hydrant but he is my go to guy for lots of purchases. The last 2 were a metal cutting blade for my Skill Saw and a bit sharpener so I don't need to run to the store every time I dull or break a bit. (IMG:style_emoticons/default/beerchug.gif) |
Superhawk996 |
Jan 5 2023, 04:37 PM
That was really interesting, thanks for posting! I don't use ratchet stands. Pin type only. I've always been a little annoyed because they have a large base and get in the way. Now I'm glad they are given how easy some of the smaller based stands tipped over! 170lbs can easily be the weight of a person walking up and leaning up against your car. "Whatcha working on....oops!" The way that 170 lbs was measured was pretty bogus and was intentional misuse. Jacking up a high Cg vehicle and placing the jack stands that close to each other and at max height one right on each side of the differential - is asking for trouble. Move them out toward the wheel ends where they belong and vehicle stability and that 170 lb number goes way up. Works great for generating YouTube clicks though! Pushing forward on the vehicle without wheels chocked - intentional misuse. Likewise that 170 lbs lateral load number would go up if the front wheels are chocked properly both fore and aft. Jack stands used on rubber pads and soft surfaces - intentional misuse. (IMG:style_emoticons/default/confused24.gif) |
VaccaRabite |
Jan 5 2023, 07:47 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Spend a little more money and get the pin type.
We had one of our admins suffer a 914 falling on him when a ratchet jack stand failed a bunch of years ago. He lived, but was lucky his wife was home, and needed a bunch of surgery to his face. I bought the pin type and got rid of all the ratcheting ones I had. When I was a lot younger and restoring WWII armored cars we would put them on undersized jackstands and get under them. So stupid. But I figured if one failed while I was under the Bren carrier I'd never know it. Zach |
Jan 5 2023, 08:09 PM
That was really interesting, thanks for posting! I don't use ratchet stands. Pin type only. I've always been a little annoyed because they have a large base and get in the way. Now I'm glad they are given how easy some of the smaller based stands tipped over! 170lbs can easily be the weight of a person walking up and leaning up against your car. "Whatcha working on....oops!" Or your wife driving into the back of your 914 when you're under it. Ask me how I know! (IMG:style_emoticons/default/shades.gif) I usually put a wheel or two under the car for that reason. I actually had an old safe with wheels that worked well for extra insurance. I’ve also added extra jacks so if one failed, it wouldn’t be an issue. I’m a big chicken about crawling under cars. But for the most part, if I have to get under a car to work on it, I’d rather it be on a lift. |
76-914 |
Jan 5 2023, 09:54 PM
That was really interesting, thanks for posting! I don't use ratchet stands. Pin type only. I've always been a little annoyed because they have a large base and get in the way. Now I'm glad they are given how easy some of the smaller based stands tipped over! 170lbs can easily be the weight of a person walking up and leaning up against your car. "Whatcha working on....oops!" Or your wife driving into the back of your 914 when you're under it. Ask me how I know! (IMG:style_emoticons/default/shades.gif) I usually put a wheel or two under the car for that reason. I actually had an old safe with wheels that worked well for extra insurance. I’ve also added extra jacks so if one failed, it wouldn’t be an issue. I’m a big chicken about crawling under cars. But for the most part, if I have to get under a car to work on it, I’d rather it be on a lift. I had left the floor jack beneath the car after lowering it onto the jack stands; just in case. Then she got pissed at me because I "unloaded" on her for trying to kill me. (IMG:style_emoticons/default/dry.gif) |
bkrantz |
Jan 5 2023, 09:55 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
arbitrary |
Jan 6 2023, 02:18 AM
Member Group: Members Posts: 81 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
The way that 170 lbs was measured was pretty bogus and was intentional misuse. Jacking up a high Cg vehicle and placing the jack stands that close to each other and at max height one right on each side of the differential - is asking for trouble. Move them out toward the wheel ends where they belong and vehicle stability and that 170 lb number goes way up. Works great for generating YouTube clicks though! Does the distance between stands really matter for that particular test on a solid axle? I’m trying to visualise the difference in how the required lateral force could vary based on jack separation distance and I’m not getting it? BTW 170 lbs of lateral force is still a fair bit. That’s far more than someone casually leaning up against a car - that’s a serious deliberate push. If we’re worried about friends doing that perhaps we should pick our friends more carefully? (IMG:style_emoticons/default/biggrin.gif) |
arbitrary |
Jan 6 2023, 02:20 AM
I brought 4 of those back from the US about 15 years ago back when checked luggage allowances were more generous - they have served me well ever since. |
Amphicar770 |
Jan 6 2023, 08:52 AM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
VaccaRabite |
Jan 6 2023, 09:31 AM
+2. Though I have found them at a much lower price in the past if you look around other then Amazon. (IMG:style_emoticons/default/aktion035.gif) |
Superhawk996 |
Jan 6 2023, 01:37 PM
Does the distance between stands really matter for that particular test on a solid axle? I’m trying to visualise the difference in how the required lateral force could vary based on jack separation distance and I’m not getting it? BTW 170 lbs of lateral force is still a fair bit. That’s far more than someone casually leaning up against a car - that’s a serious deliberate push. If we’re worried about friends doing that perhaps we should pick our friends more carefully? (IMG:style_emoticons/default/biggrin.gif) Some of this depends on where the lateral force is applied vs the center of gravity. To try to keep it simple with no math. Far left - simple block mass with a single jack stand under it. We would all agree this is dangerous and would be easily disturbed by applying a lateral force (F). That force would cause the mass to rotate (overturning moment) and it would tip over the jack stand in one direction on another depending on whether the lateral force F is applied higher than or lower than the center of gravity. Middle - I’ve represented mass more like a car. Some of the mass is centralized but other mass is overhanging the jack stands. Although there are now two - they are too close to the vehicle center line. Far right - same representation of mass. But now the jackstands are out underneath the outermost masses as far as they can go. In this scenario - force F is almost all lateral and doesn’t create the tendency for tipping due to rotation of the vehicle mass about the center line. Hopefully this helps. Attached thumbnail(s) |
914Sixer |
Jan 6 2023, 01:40 PM
Been using the ratchet jacks WITH pins for a long time.
mgarrison |
Jan 6 2023, 05:27 PM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
My first thought watching was why are the jack stands so close together? But, it makes for interesting video and more clicks!
I have both types of jack stands; pins and ratchet but when our teenage son started working on his car I sprang for a QuickJack. Figured it was cheap insurance against mistakes, and I've coached him to add the pin type stand under the pivot of the QJ just in case...Now he's working as a mechanic at a local shop and some of his lift stories give me the willys! (IMG:style_emoticons/default/wacko.gif) QJ seems to be a good solution for everything from the Miata to the 914 to my Raptor (I got the 7000lb version and SUV kit so my bases were covered) Thanks for sharing the video - good things to know! (IMG:style_emoticons/default/idea.gif) |
DBF |
Jan 9 2023, 09:54 AM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
A friend of mine was killed when his big riding mower feel on him while on jack stands. He was a careful guy, and on concrete. Since then, I always use a couple floor jacks as an extra safety measure when under a car on jack stands. The jacks are 90 degree from each other. My hope is if the car goes forward or sideways, one of the jacks will likely tip over with the jack stands, but the other will roll with the car and not tip over and hold the car up.
Beach914 |
Jan 9 2023, 03:14 PM
Senior Member Group: Members Posts: 964 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
Harbor Freight has just come out with a set of 'Esco" like (pinned post type) jack stands rated at 6000lbs. i know there are plenty of those that avoid anything HF but they took a beating on their ratcheting type failure so you'd think they learned something.
I bought two pair to replace my ratcheting type which I've never really trusted. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:58 AM |
