Steering play/slack |
ronan |
Jan 13 2023, 05:21 PM
Newbie Group: Members Posts: 13 Joined: 23-December 22 From: Phoenix Member No.: 27,051 Region Association: Central California |
I just took apart the steering wheel on my 75 1.8, because there is way too much play from side to side and top to bottom. The steering wheel moves about a half inch in any direction. As I took it apart I gathered what seem to be disintegrated parts of an old bearing, or something else, I don’t know, the image is attached. From what I could tell everything looked normal (I am a new 914 owner and new to old cars in general though, so I don’t really know what to look for.) Has anyone had this problem before? What is the disintegrated stuff?
Attached thumbnail(s) |
Puebloswatcop |
Jan 13 2023, 09:14 PM
Senior Member Group: Members Posts: 1,370 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Where exactly were you in the dis assembly process when you found this. It is possible that it's part of a bearing...but need to know where it was found.
ronan |
Jan 13 2023, 09:38 PM
Where exactly were you in the dis assembly process when you found this. It is possible that it's part of a bearing...but need to know where it was found. Found it after in the housing for the turn signals and ignition, in that chamber. There’s a bearing in there that all of this crud was sitting on. |
Steve |
Jan 13 2023, 11:10 PM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
That’s a common problem on 75-76 914’s. The inside of the plastic bearing disintegrates. The quick fix versus a new bearing was to cram this sleeve down the inside of the bearing. They used to make one for the 914, I can’t find it. It looks like this one. https://www.stoddard.com/92834773902.html.html
rhodyguy |
Jan 13 2023, 11:26 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,054 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
914rubber offers them. The bushing and the cover as a package.
ronan |
Jan 16 2023, 11:06 AM
Mikey914 |
Jan 16 2023, 12:01 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
There is a bearing in the column that I may or may not have, but it's possibly that, and this is the one toward the rack.
https://914rubber.com/steering-bearing-1 There are others but this is where I'd put my money Attached thumbnail(s) |
Steve |
Jan 16 2023, 12:59 PM
That’s a common problem on 75-76 914’s. The inside of the plastic bearing disintegrates. The quick fix versus a new bearing was to cram this sleeve down the inside of the bearing. They used to make one for the 914, I can’t find it. It looks like this one. https://www.stoddard.com/92834773902.html.html https://www.autohausaz.com/pn/12912543-9283...o0aAiuGEALw_wcB Or Pelican its the same part. https://www.pelicanparts.com/More_Info/9283...aAi6zEALw_wcB#0 |
mmascari |
Feb 2 2023, 05:21 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
There is a bearing in the column that I may or may not have, but it's possibly that, and this is the one toward the rack. https://914rubber.com/steering-bearing-1 There are others but this is where I'd put my money How difficult is it to replace this? I have the same issue, the shaft moves and it is awful when driving and hitting bumps. Any direction from experts here on how to replace? |
Superhawk996 |
Feb 2 2023, 07:46 PM
914 Guru Group: Members Posts: 5,723 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
How difficult is it to replace this? I have the same issue, the shaft moves and it is awful when driving and hitting bumps. Any direction from experts here on how to replace? Replace the bearings / bushing in the steering column. Not a terrible job but it will be a lot easier if you just remove the steering column from the vehicle. The bearing that Mikey914 showed, supports the steering shaft that comes directly out of the steering rack. It is located in the Frunk under the gas tank. That bearing being bad will not cause you to feel vertical or horizontal slop in the steering wheel as you go over bumps. See Haynes manual or factory manual on info how to remove the steering column. It’s a couple hour job. The exact parts you’ll need will be dependent on whether your steering column is early or late style. |
Mikey914 |
Feb 8 2023, 11:43 AM
There is a bearing in the column that I may or may not have, but it's possibly that, and this is the one toward the rack. https://914rubber.com/steering-bearing-1 There are others but this is where I'd put my money How difficult is it to replace this? I have the same issue, the shaft moves and it is awful when driving and hitting bumps. Any direction from experts here on how to replace? For the bearing I showed you have to get under the fuel tank. It could be possible to get to it from underneath, but is probably easier to remove the tank. |
Lo-Fi Version | Time is now: 18th April 2024 - 12:14 PM |
