Weird Door Lock Mechanism Behavior |
bkrantz |
Jan 16 2023, 08:58 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I discovered a problem with my door locks (both sides). Last year, I transferred the lock cores to the new repro handles. That required a bit of machining of the holes for the cylinders in the new handles, but in the end, the keys worked fine in both L and R handles.
But when I got done with my build, I found that the keys barely worked. I could lock the doors with the key with some effort. But I could only barely use the key to unlock the doors, with lots of effort and jiggling. Attached thumbnail(s) |
bkrantz |
Jan 16 2023, 08:59 PM
Here's some excess details. View of the right door inside, lock open.
bkrantz |
Jan 16 2023, 09:00 PM
Turn the key to lock the door.
bkrantz |
Jan 16 2023, 09:01 PM
Door is locked.
bkrantz |
But the locking lever inside has barely moved.
bkrantz |
Jan 16 2023, 09:02 PM
And the key will not rotate to unlock the door.
bkrantz |
Jan 16 2023, 09:03 PM
Until I pushed the interior lever to "lock".
bkrantz |
Jan 16 2023, 09:04 PM
Then the key rotates to "unlock".
bkrantz |
Jan 16 2023, 09:05 PM
The interior lever also moves to "unlock".
bkrantz |
Jan 16 2023, 09:06 PM
And the door opens.
bkrantz |
Jan 16 2023, 09:08 PM
On the other side, I have the door card and plastic sheet off. I hit the lock mechanism and linkage with a healthy dose of spray grease.
bkrantz |
Jan 16 2023, 09:11 PM
That seemed to help. When I lock the door with the key, the interior lever moves to "lock". And then I can unlock the door with the key.
Anyone ever see this before? Any reason the door card would interfere with the lock linkage rod? (It does not seem to make contact.) Attached thumbnail(s) |
Root_Werks |
Jan 17 2023, 06:19 PM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
My 914 door locks work very smooth and easy. Couple things I did to ensure they functioned like this:
Ensure your key pulls the wafers in 100%, even a tiny bit of wafer sticking up can make the key not want to rotate. Really clean and lube the inner door mechanism. I removed mine, really cleaned until everything moved freely, nice solid clicks and snaps into place. Pay attention to inner door handle adjustment. There isn't much, you can scoot the inner handle a little forward and back to get the lock position correct. It takes fiddling, but will say my current 914 has the smoothest locks I've ever known on any 914 I've owned. Totally worth the time. When I turn my key outside, the inner lock will sit flush with the handle. |
bkrantz |
Jan 17 2023, 08:46 PM
Thanks.
Any other suggestions out there? |
theer |
Jan 17 2023, 10:11 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Second the inner door mechanism. The pieces need to slide past each other. Dirt and old grease can gum it up. Your car looks really clean though!
76-914 |
Jan 17 2023, 10:14 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I think your linkage is dragging. Is it in a bind with the door card? I ask because in the first pic that black plastic escutcheon appears to protrude away from the card. I've never needed to lube that linkage either. If it drags in the rubber holders I'd check the linkage to be sure it isn't rough on the exterior. (IMG:style_emoticons/default/beerchug.gif)
rhodyguy |
Jan 18 2023, 08:57 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are you using a longer screw to retain the inner release surround? If the pass side works, the screw on that side is the correct length.
dr914@autoatlanta.com |
Jan 18 2023, 10:34 AM
914 Guru Group: Members Posts: 7,853 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
If you have cleaned the latching mechanisms in the door THOROUGHLY and lubricated them so the "C" piece slides up and down easily, it is the repro door latch that is not working properly. They are really really bad
I discovered a problem with my door locks (both sides). Last year, I transferred the lock cores to the new repro handles. That required a bit of machining of the holes for the cylinders in the new handles, but in the end, the keys worked fine in both L and R handles. But when I got done with my build, I found that the keys barely worked. I could lock the doors with the key with some effort. But I could only barely use the key to unlock the doors, with lots of effort and jiggling. |
Olympic 914 |
Jan 18 2023, 03:24 PM
Group: Members Posts: 1,665 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Are you using a longer screw to retain the inner release surround? If the pass side works, the screw on that side is the correct length. (IMG:style_emoticons/default/agree.gif) Check this, see how it works without the trim piece installed. If you have the wrong screw in there it will bind. |
Root_Werks |
Jan 18 2023, 03:30 PM
Turning into a good resource thread!
Remembering now one of my inner handles was pretty worn out. The holes the rod went into were oval, not round. Just enough the throw from the key wouldn't seat the inner lock all the way. There isn't much tolerance for worn out parts if you want the whole system to work smoothly. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:59 AM |
