2 Custom Fuel Gauges |
jbell959 |
Jan 21 2023, 09:41 PM
Newbie Group: Members Posts: 3 Joined: 2-May 21 From: CA Member No.: 25,505 Region Association: None |
Up for sale are a couple of custom gauges I built.
1. Backdated 74-76 Fuel/Temp Gauge - I built this gauge for a customer that decided to go with a triple gauge. Rather than take this apart we started with a new donor. This is basically a stock 74-76 gauge that was backdated with the silver button, early style temp face, and early style bezels. The major white and red regions on this face are in the same place as the original face so you get the earlier look and retain the accuracy. The original face will also be included if you prefer to switch back. I can also switch it to a numeric face. I'd like to get $300 shipped SOLD 2. Replica 914-6GT Fuel Gauge - This gauge takes 3 different cores to get the correct case, bezel, needle, and fuel movement. To get the correct placement of the low fuel light I use an internally mounted LED. Building this gauge is labor intensive so in addition to buying the 3 cores it gets expensive. I can build less expensive versions if you don't need the studs in the back or the accurate needle. I'd like to get $450 shipped SOLD Attached thumbnail(s) |
Aerostatwv |
Jan 21 2023, 09:51 PM
Member Group: Members Posts: 117 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
PM sent.
Thank you, Chris |
jbell959 |
Jan 27 2023, 11:01 PM
Combo gauge is sold. Fuel Gauge is still available.
I have the parts to build another of these combo gauges if anyone needs one. |
Bullethead |
Jan 28 2023, 07:07 AM
Oil Cooled heart Group: Members Posts: 897 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
You have PM... |
jbell959 |
Jan 30 2023, 03:39 PM
Thanks 914World!
Both are sold... I have a lot of parts so if anyone else is looking for one of these or something similar, just ask. |
Lo-Fi Version | Time is now: 21st May 2024 - 04:29 PM |
