Karl's Project Update, Clear here for the latest |
Qarl |
Jul 25 2003, 08:07 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Okay... I decided to start a Gint-like thread and just post progress instead of starting a new subject each time I do something neat.
Latest project.... Pedal cluster rebuild. This is really VERY easy to do. I had the pieces powder coated. Installed new bushings. Cleaned up everything and reassembled. I'm also installing AJ billet pedals (I've got the billet gas pedal too). Attached image(s) |
tahoward |
Jul 25 2003, 08:09 PM
Member Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 |
Mental note to self: Must have billet pedals! Very nice! Can't wait to see your car finished.
Qarl |
Also had the light buckets powder coated... although no one will see them but me.
Man these things were nasty before I bead blasted them. NOW! Nice and shiny Attached image(s) |
ein 6er |
Jul 25 2003, 08:12 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
did you plate the hardware on the cluster yourself?
Qarl |
Jul 25 2003, 08:13 PM
Cluster hardware cleaned up very nice to look new. I lucked out.
I just garmed out all the black pieces for gloss powdercoast after I bead blasted them at home. Same guy who did this... Attached image(s) |
rhodyguy |
Jul 25 2003, 08:17 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
nice karl. with the influx of parts i take it your car is on the road to being on the road. endevour to persevere.
kevin |
Qarl |
Jul 25 2003, 08:23 PM
Unfortunately... not much work on the body other than fitting flares. LOTS of rain here is making it hard to get body work done... humidity is high and it's so friggin hot.
That's okay... I'd rather the car get painted in a month or two after the rains start subsiding a little more... I basically have just been refinishing/replating everything so that when I do get the body back... everything (for the most part) is ready to go back on clean and refreshed. Carpet came in this week... Gauges are due in next week. Interior is all redyed (I do need to redo the door panels). Tranny rebuild project is next... 901 - GT torsen differential, billet intermedate plate with new bearings, billet side cover, new synchros, 1st gear dog teath, seals, and regearing for the engine. |
vortrex |
Jul 25 2003, 08:33 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
so when is your targeted completion date? it's nice to see someone dumping this kind of money into a 914! I really like what you're doing with the car.
Brad Roberts |
Jul 25 2003, 08:46 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Do not let Karl fool you. Not all pedal assemblies come apart easily. 90% of them are a serious pain in the ass to get apart (like getting the roll pin out of the clutch arm).
Looks great.. I'm going thru the same pain on the 3.6 car soon. B |
Qarl |
Jul 25 2003, 08:55 PM
Dumping money is right... (IMG:style_emoticons/default/bootyshake.gif) I am totally aware that I am stupidly dumping inordinate amounts of money into this car that I will NEVER recover.
But I am doing this once (I am building my dream 914 to last and keep). It will, for all intents and purposes, be basically a NEW 914. Almost everything is being replaced, upgraded, rebuild, replated, refinished, restored, etc. This car has consumed me for many years (lots of dreaming). I have loved 914s since my first car when I was 16. I've spent countless hours searching through catalogs and magazines over the years for ideas. Luckily the internet has made my thought process easier over the past several years. Groups like 914club and the Pelican Parts BB make the free exchange of knowledge and ideas so much easier. Thanks to Brad for making THIS board the best! Thanks to everyone else for contributing. Working on this car is also my therapy and release for the stresses I deal with daily at work and the life my wife and I live. Realistic completion date is the end of the year... I figure another 6-8 weeks for body work (he's slow but good).... A month to reassemble (in my spare time).... And a month to install everything at the shop, troubleshoot, tweek, balance, etc. Maybe it will make a nice Christmas present. |
Qarl |
Jul 25 2003, 08:58 PM
Oh yeah... the roll pin was a BITCH.
I drilled and drilled and cursed and swore. Took it to a machine shop to get pressed out. The guy placed it on a vice... took a hardned steel punch and a big f-ing hammer and WHAM it was out in 1 second. No charge. (Of course I was also picking up my lower valve covers for machining.). If I can give any advice to someone restoring a car... two things.... Air compressor and bead blaster. It's made refinishing crap so much nice than dealing with a wire brush or chemicals. |
Curvie Roadlover |
Jul 25 2003, 09:05 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Karl, I have a question for you. Do you think that , when completed, you're car will be so nice that you'll be afraid to drive it? At least to some degree? You may need to get another one to use for a fun car. If your petal cluster is anything like how the rest of your car will be upon completion, you'll have to put it in a climate controlled showcase. (IMG:style_emoticons/default/pray.gif)
Qarl |
Jul 25 2003, 09:38 PM
This car will NOT be a daily driver, but a weekend, and fun car. Car shows, maybe a driver's ed event. Cruising for the weekend.
My wife probably WON"T like riding in it because it will be a very stiff car (although Mueller's needle bearings will help a little). No.. .it won't be a garage queen, although I did meet with my builder today and he's going to add A/C to the garage... (IMG:style_emoticons/default/smile.gif) Here are the valve covers... they were painted with VHT wrinkle finish paint. Attached image(s) |
Britain Smith |
Jul 25 2003, 09:50 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Nice work...I love it when people put the effort in to powder paint all the pieces.
I expecially like the fan housing...who did that for you? I am getting my fan housing in the mail soon and I haven't decided what I want to do to it. I like the idea of painting the housing black...that is powder painted also right? What kind of finish is on the actual fan? From what I understand, it is magnesium which can be difficult to make look good? Let me know, Britain |
Qarl |
Jul 25 2003, 10:01 PM
Housing was powdercoated in gloss black
Fan was blasted and coated in silver powder coat and then clearcoated. DO NOT powdercoat the inside of the fan housing area that the alternator slides into. It is basically an interference fit and even the powdercoat layer will not allow you to install the alternator. Have it masked off... as well as any screw threads. Same goes for the pedal cluster... cork off the through-tubes to allow the bushings to fit and tape off any screw threads. |
URY914 |
Jul 25 2003, 10:04 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,563 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Karl,
You need a CPM schedule of your project. I do them for work all the time. Make a list of the activities and the duration, than put them in order. When you find your longest string, you have the credical path and with a time scale you can figure out your completion date. Paul |
Qarl |
Jul 25 2003, 10:13 PM
Thanks for the info Paul... this coming from someone who has taken 24 years to get his car where it is....
Just kidding. If you look at my website and my progress page.. you will see large gaps in activity. This is due to lack of time, kid being sick, work taking too much time, me not feeling well. http://www.my914-6.com/progress.htm But you will also notice a lot of activity in the last few months that has been pretty consistent. Of course I don't document EVERYTHING! |
Andyrew |
Jul 25 2003, 10:48 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Karl that is going to look soooo cool. I cant wait to see it all together, heck I cant wait to see my car all together!
Mueller |
Jul 25 2003, 10:56 PM
Karl,
It's great to see progress like this (IMG:style_emoticons/default/smile.gif) Not that I know what to look for, but are those valve covers modified for use in the 914 yet?? |
Qarl |
Jul 25 2003, 10:59 PM
Mueller...
Yes the lower valve cover ribs were machined down to allow clearance on the rear trailing arms. The ribs come up about 1/4" higher than the valve cover mounting bolt thru-holes. I had the ribs machined down to the level of the holes. About $40 for the machining. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:52 AM |
