Fuel line clips?, Calling 914 rubber! |
Jan 24 2023, 03:16 PM
I can convince my young ME son to do this.
He has tooling , SW, and a 3d printer. He is trying to start a small side business doing modeling...but this would get him into something small to start. If someone else wants to step up...please do. But...I can convince him to do them...and he is a real bonified mechanical engineer that makes things for a living...so they won't be meh. I have a 75 here, I will go see if those are in good enough shape to measure. or if I even have them (IMG:style_emoticons/default/smile.gif) Rich |
Van B |
Jan 24 2023, 04:18 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
How well does 3D print plastic hold up to engine bay heat in the long run?
JamesM |
Jan 24 2023, 06:53 PM
Senior Member Group: Members Posts: 1,896 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Van B |
Jan 24 2023, 07:54 PM
How many needed per car, can someone verify? I see two on the bottom edge of the rear firewall of my 74 car. I think there are two on the pass side engine bay, but do not have access at the moment to verify. They are injection molded nylon. Do all years have these or just the later cars? yes - 2 on rhs of upper engine bay. just noticed one of mine is half broken like Van's. failed since i installed metal fuel lines in engine bay. old plastic gave out. they are all at the end of their useful lives. this is a 74 L jet. There are actually four in the engine bay on a 74-76 Attached thumbnail(s) |
JeffBowlsby |
Jan 24 2023, 09:01 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
4 per car. With only 100 as the first lot, thats only enough for 25 cars. I bet a 500 lot first order would sell out quickly. These are very much needed.
mb911 |
Jan 24 2023, 09:09 PM
914 Guru Group: Members Posts: 6,848 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
wonkipop |
Jan 24 2023, 11:22 PM
Advanced Member Group: Members Posts: 4,289 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
How many needed per car, can someone verify? I see two on the bottom edge of the rear firewall of my 74 car. I think there are two on the pass side engine bay, but do not have access at the moment to verify. They are injection molded nylon. Do all years have these or just the later cars? yes - 2 on rhs of upper engine bay. just noticed one of mine is half broken like Van's. failed since i installed metal fuel lines in engine bay. old plastic gave out. they are all at the end of their useful lives. this is a 74 L jet. There are actually four in the engine bay on a 74-76 thats what i said. 2 in upper engine bay. other 2 are in lower engine bay or do i have my hemispheres wrong from living in australia. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) i agree with jeff, a run of 100 is gonna sell out. fast. (IMG:style_emoticons/default/smile.gif) they should be nylon. not sure printing stuff is nylon. nylon is the go. |
Van B |
Jan 24 2023, 11:33 PM
Ah I see… you were completing Jeffs initial count. Since they are all on the passenger side (right side for you commonwealth folks) I wasn’t sure if you were both counting the same two.
wonkipop |
Jan 24 2023, 11:44 PM
Ah I see… you were completing Jeffs initial count. Since they are all on the passenger side (right side for you commonwealth folks) I wasn’t sure if you were both counting the same two. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) don't worry i got confused when he said they were on the passenger side. LOL. (IMG:style_emoticons/default/beerchug.gif) |
johnorm |
Jan 25 2023, 12:00 AM
Newbie Group: Members Posts: 26 Joined: 28-October 18 From: Canada Member No.: 22,610 Region Association: Canada |
One other option is using a hose clamp separator that are available at most hotrod / performance shops (and oddly on Amazon). They are available in multiple ID's, they are a clean and neat solution, can be had in hard plastic or aluminum plus they are not expensive. They are more suited for rubber hose vs steel lines but I have used them on both (on steel I lined the clamp with rubber).
Jan 26 2023, 11:53 PM
Ok,
Any idea which one can be gently removed with breaking it? It seems the two by the battery are into the long, so there is no access to the back side. Where are the other two? |
wonkipop |
Jan 27 2023, 12:00 AM
Ok, Any idea which one can be gently removed with breaking it? It seems the two by the battery are into the long, so there is no access to the back side. Where are the other two? into a space just as bad i think. the double skin with cavity lower firewall behind passenger seat? i've never cut into it to know but i'm sure several thousand members here have doing rustorations. i think they are all equally heat affected. if mine is anything to go by the one that is furtherest towards the rear in the upper engine bay is still intact. possibly least affected by engine heat or battery acid over life of car and might be the candidate? but they are all going to be dicey to try and extract. |
Van B |
Jan 27 2023, 10:00 AM
Ok, Any idea which one can be gently removed with breaking it? It seems the two by the battery are into the long, so there is no access to the back side. Where are the other two? I'll have a look this weekend. Maybe with a borescope camera and a funny tool I could work it from the backside or at least recover the pin through the ~1" vent hole where the long meets the trunk. |
rgalla9146 |
Jan 27 2023, 10:18 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
How about this..... pre-drill a hole in the pin and draw it out with a small sheet metal screw. OR push it through with the metal screw still attached and retrieve it through an ajacent (new) hole using a magnet |
rgalla9146 |
Jan 27 2023, 11:22 AM
This one was successfully removed and re-installed....there was access behind on the donor. The blue one pictured is a good alternative.....found on many VWs.....late air cooled and watercooled Attached thumbnail(s) |
rgalla9146 |
Jan 27 2023, 11:27 AM
Various sizes too Attached thumbnail(s) |
Van B |
Jan 27 2023, 12:38 PM
those paperclip style are my fall back. double them up and use a push through plastic fire wall pin. But I still say these are a worthwhile reproduction.
Mikey914 |
Jan 27 2023, 06:05 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These look less viable for reproduction. Total investment will be several thousand dollars, sure I can do in quantity but bottom line is that I think there’s not enough interest to launch these. There are a few other projects already in the works that need the resources.
Van B |
Jan 27 2023, 06:30 PM
C’mon now Mark! It’s Friday, you’re tired from working all week and sending me car parts. You just need a burger and a shake, some rest, and then inspiration will strike!
Maybe a difference method of attachment? |
Jan 27 2023, 07:02 PM
Axel made a prototype, I will see about prying one out this weekend to get the back side bit measured up.
Rich |
Lo-Fi Version | Time is now: 13th May 2024 - 03:32 AM |
