Another what's this question, It must be aftermarket, never seen it on an engine before |
Type 47 |
Jan 27 2023, 06:12 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
914werke |
Jan 27 2023, 06:14 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Timing bar. stock on bus engines
Type 47 |
Jan 27 2023, 06:29 PM
bdstone914 |
Jan 27 2023, 06:59 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
wonkipop |
Jan 27 2023, 07:14 PM
Advanced Member Group: Members Posts: 4,299 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Timing bar. stock on bus engines here is the engine #. The car was 696 in the 1st production run for 75'. Were they pulling 2.0 stock from the bus engine pool? It is not a bus engine. Someone probably added the timing strip. The bus engine also had a plastic screen over the fan inlet. bus engines usually did not have the timing hole drilled out in the fan casting along with the little plug to seal it. instead the timing gauge was used. made it easier for mechanics working on the bus to do timing as the engine bay is not very high to put your head in there with a strobe timing light. not sure why you would add it to a 914 engine. you would have to put a mirror on the firewall to see it? |
Type 47 |
Jan 27 2023, 07:32 PM
Timing bar. stock on bus engines here is the engine #. The car was 696 in the 1st production run for 75'. Were they pulling 2.0 stock from the bus engine pool? It is not a bus engine. Someone probably added the timing strip. The bus engine also had a plastic screen over the fan inlet. bus engines usually did not have the timing hole drilled out in the fan casting along with the little plug to seal it. instead the timing gauge was used. made it easier for mechanics working on the bus to do timing as the engine bay is not very high to put your head in there with a strobe timing light. not sure why you would add it to a 914 engine. you would have to put a mirror on the firewall to see it? Right. that's why i took a pic today...we are putting it in tomorrow and I won't see it again. |
wonkipop |
Jan 27 2023, 08:03 PM
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) @Type 47
probably a previous owner down the track liked to do the timing with a mirror. quirky! |
bkrantz |
Jan 27 2023, 08:19 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Maybe someone scavenged the outer fan housing from a bus motor?
rgalla9146 |
Jan 28 2023, 07:56 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
How are you going to check your timing ?
Better mark the flywheel before installing the engine or poke a large hole in your firewall (IMG:style_emoticons/default/smile.gif) Beautiful engine ! |
Type 47 |
Jan 28 2023, 02:12 PM
How are you going to check your timing ? Better mark the flywheel before installing the engine or poke a large hole in your firewall (IMG:style_emoticons/default/smile.gif) Beautiful engine ! It has the normal 914 timing marks also. |
rgalla9146 |
Jan 28 2023, 11:27 PM
How are you going to check your timing ? Better mark the flywheel before installing the engine or poke a large hole in your firewall (IMG:style_emoticons/default/smile.gif) Beautiful engine ! It has the normal 914 timing marks also. The view of the normal timing marks is through the hole at the top of the fan housing. Your fan housing (for a VW bus) doesn't have the normal 914 hole. (IMG:style_emoticons/default/sad.gif) Your work is beautiful....am I missing something ? |
wonkipop |
Jan 29 2023, 12:41 AM
How are you going to check your timing ? Better mark the flywheel before installing the engine or poke a large hole in your firewall (IMG:style_emoticons/default/smile.gif) Beautiful engine ! It has the normal 914 timing marks also. The view of the normal timing marks is through the hole at the top of the fan housing. Your fan housing (for a VW bus) doesn't have the normal 914 hole. (IMG:style_emoticons/default/sad.gif) Your work is beautiful....am I missing something ? (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) yeah, you're missing something. the beautiful motor is not his. i posted it to show him about the timing hole. (IMG:style_emoticons/default/biggrin.gif) its ratwell's motor from his bus. see ratwell's website about buses. read the topic from top to bottom. don't worry i've done it before and missed the flow of the thread. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:01 PM |
