Is this normal or not normal, shift linkage |
Type 47 |
Jan 30 2023, 04:30 PM
Senior Member Group: Members Posts: 781 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
brant |
Jan 30 2023, 04:41 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
there is an o-ring on the cover/housing...
you can pull it and replace or not worry too much.. either way. |
Superhawk996 |
Jan 30 2023, 05:35 PM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Is the cover intended to catch this leak . . . (IMG:style_emoticons/default/av-943.gif) That does seem to be what they actually do . . . . or is something not right? Defiantly not right. brant is referring to the o-ring for the housing but there is also a seal in that assembly that seals to the shift rod that is sliding in/out of the housing and as it pivots fore/aft. Based on where your leak is, I think it’s that internal seal. I know there are other threads on this - probably with seal info for replacement. |
Jan 30 2023, 05:38 PM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
There is an o-ring on the body to tranny
There is a shaft seal right under that arm you can see. There is a thread I just posted detailing this with pics. It’s on the first two or three pages. |
Superhawk996 |
Jan 30 2023, 05:39 PM
930cabman |
Jan 30 2023, 05:40 PM
Advanced Member Group: Members Posts: 3,007 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Is the cover intended to catch this leak . . . (IMG:style_emoticons/default/av-943.gif) That does seem to be what they actually do . . . . or is something not right? Defiantly not right. brant is referring to the o-ring for the housing but there is also a seal in that assembly that seals to the shift rod that is sliding in/out of the housing and as it pivots fore/aft. Based on where your leak is, I think it’s that internal seal. I know there are other threads on this - probably with seal info for replacement. Agreed, I would bet the leak is from the seal and not the O ring. Plastic cover is meant to keep water/dirt from the linkage area. |
Superhawk996 |
Jan 30 2023, 05:57 PM
Had that bastard cover dump water and stinky trans oil mix on my head once! (IMG:style_emoticons/default/hissyfit.gif)
Lesson learned - don’t be under the cover when you loosen it. |
rhodyguy |
Jan 30 2023, 06:08 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Plan replacing the ball cup bushing while you’re in there. Take the time to do the rest of the bushings too. You will need 2 new set screws. Typically a one time use item. Use the old ones setting the linkage up and swap them at the end. Mark/index all connection points with a fine tip sharpie.
Craigers17 |
Jan 30 2023, 06:18 PM
Senior Member Group: Members Posts: 731 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Type 47 |
Jan 30 2023, 06:54 PM
Thanks guys!!! I will start reading the pelicanparts article and get the seal and o ring.
Jan 30 2023, 10:41 PM
Seal and o-ring are part of the tranny gasket set.
I could not find them seperatly. Cup bushings, get two (one for that area, one for the shifter. Console bushing, in my opinion, is far too loose in stock form. The shifter rod moves too much at that key point. Go to gpr.com and buy the bronze bushing….it’s nice and snug. Seems he is the only one who sells it. Check the other thread I just posted fir some pics about this. Rich |
rhodyguy |
Jan 31 2023, 07:36 AM
The cover has a small hole in the bottom side that serves as a drain…I think.
bdstone914 |
Jan 31 2023, 08:16 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Seal and o-ring are part of the tranny gasket set. I could not find them seperatly. Cup bushings, get two (one for that area, one for the shifter. Console bushing, in my opinion, is far too loose in stock form. The shifter rod moves too much at that key point. Go to gpr.com and buy the bronze bushing….it’s nice and snug. Seems he is the only one who sells it. Check the other thread I just posted fir some pics about this. Rich Rich, The side shift tran shifter does not use a cup bushing. That is on the tail shift shifter. |
bdstone914 |
Jan 31 2023, 08:22 AM
Seal and o-ring are part of the tranny gasket set. I could not find them seperatly. Cup bushings, get two (one for that area, one for the shifter. Console bushing, in my opinion, is far too loose in stock form. The shifter rod moves too much at that key point. Go to gpr.com and buy the bronze bushing….it’s nice and snug. Seems he is the only one who sells it. Check the other thread I just posted fir some pics about this. Rich Rich Dauenhauer (914werke) is who has the bronze console bushing. GPR.com is a website for ground positioning radar. I dont know if the old German parts and Restoration is still around. Edit. I found German Parts and Restoration and they charge $23.50 for the bushing whilt Rich charges $9.14. Attached thumbnail(s) |
Jan 31 2023, 06:15 PM
Seal and o-ring are part of the tranny gasket set. I could not find them seperatly. Cup bushings, get two (one for that area, one for the shifter. Console bushing, in my opinion, is far too loose in stock form. The shifter rod moves too much at that key point. Go to gpr.com and buy the bronze bushing….it’s nice and snug. Seems he is the only one who sells it. Check the other thread I just posted fir some pics about this. Rich Rich, The side shift tran shifter does not use a cup bushing. That is on the tail shift shifter. Good, less work this time, and now I have a spare bushing (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 10:29 AM |
