Correct front brake hose for a 911 suspention swap? |
Tdskip |
Feb 1 2023, 11:57 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Ah the hazards of Porsche lego sets...
Nearly done with swapping in a 911 front suspension on the '74 blue 914/6 build and hit an unexpected issue. The brake hose that was on the car with its original suspension fits a strut with an open mounting point whereas the 911 struts I put on the car have a closed and too narrow closed opening. In other worse the metal end of the brake hose won't fit through the opening on the new strut with the red arrow and is designed to use an open mounting point as shown by the yellow arrow. Anyone know offhand what year 911 brake hose would work? I am thinking pre-1970 but that is a bit of a guess frankly. Thanks! |
914Sixer |
Feb 1 2023, 12:34 PM
914 Guru Group: Members Posts: 8,868 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Use the 914-6 or 911 hoses with line holders up to 1973. You need brake spring(27) and 911 clip (26). Clip 26 is completely different than 914 version. You can use the 1 piece late 73-76 brake line though.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 24th April 2024 - 11:51 AM |
