Air box connection, Ideas on best fixes? |
Motosan |
Feb 4 2023, 12:57 PM
Newbie Group: Members Posts: 33 Joined: 14-October 22 From: California Member No.: 26,919 Region Association: Southern California |
I have noticed that the air box connection is loose after getting to work on the car. Took the box off, changed the filter and vacuum hoses but noticed the connection isn’t tight after getting everything back together. I’m not married to the stock box if there is a better solution but just not sure if this connection is a wear item or I’m missing a way to tighten this connection.
Thanks! Attached thumbnail(s) |
emerygt350 |
Feb 4 2023, 12:58 PM
Advanced Member Group: Members Posts: 2,067 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
You mean you can't tighten that flat head bolt enough for a tight fit?
You can use pliers to massage that bent metal piece to increase the clamping pressure, but it doesn't need to be particularly tight. |
emerygt350 |
Feb 4 2023, 01:01 PM
Are you doing new hoses or something?
Motosan |
Feb 4 2023, 01:05 PM
You mean you can't tighten that flat head bolt enough for a tight fit? You can use pliers to massage that bent metal piece to increase the clamping pressure, but it doesn't need to be particularly tight. It’s loose on the top connection where there isn’t a way to tighten beyond just pushing it on, and yes I’m changing hoses. This arrow better represents where it’s lose. Attached thumbnail(s) |
rhodyguy |
Feb 4 2023, 01:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,055 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I would WTB a dif clamp. Your’s looks bent to the point that the bolt portions of the clamp make contact before it fully tightens.
Motosan |
Feb 4 2023, 01:20 PM
r_towle |
Feb 4 2023, 02:08 PM
Custom Member Group: Members Posts: 24,560 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Add a clamp, or new adhesive.
It should be tight to aid in not having a leak |
Cairo94507 |
Feb 4 2023, 02:13 PM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I thought (on my '73 2.0) there was a rubber sleeve that went into the airbox and made a secure, seal when tightened. (IMG:style_emoticons/default/confused24.gif)
emerygt350 |
Feb 4 2023, 02:40 PM
I would just bend that metal piece back into shape. No need to go crazy with it.
Also, be careful as you replace the hoses. Many of the diagrams out there do not show the correct piping. Particularly for the decel valve. |
914sgofast2 |
Feb 4 2023, 04:30 PM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I think you need to replace the rubber seal that seals the connection between the air filter box and the throttle body opening. The purpose is to provide an air tight seal at the joint so no dust gets sucked in through the throttle body/air box interface.
Superhawk996 |
Feb 4 2023, 06:10 PM
914 Guru Group: Members Posts: 5,726 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Superhawk996 |
Feb 4 2023, 06:17 PM
I think you need to replace the rubber seal that seals the connection between the air filter box and the throttle body opening. The purpose is to provide an air tight seal at the joint so no dust gets sucked in through the throttle body/air box interface. (IMG:style_emoticons/default/agree.gif) Tried to find part in PET - it is vague as can be on the air box throttle body for the various engines - no clear pictures or part number |
emerygt350 |
Feb 5 2023, 07:17 AM
914sgofast2 |
Feb 5 2023, 01:09 PM
914Rubber sells them. It’s called a 2 liter flange gasket for the air cleaner.
Superhawk996 |
Feb 5 2023, 01:26 PM
914Rubber sells them. It’s called a 2 liter flange gasket for the air cleaner. (IMG:style_emoticons/default/smilie_pokal.gif) |
mgphoto |
Feb 8 2023, 06:06 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Mine has a habit of popping out of the flange, I added a loop of lock wire to keep it in position.
Lo-Fi Version | Time is now: 19th April 2024 - 04:21 PM |
