Air box connection, Ideas on best fixes? |
Motosan |
Feb 4 2023, 12:57 PM
Newbie Group: Members Posts: 33 Joined: 14-October 22 From: California Member No.: 26,919 Region Association: Southern California |
I have noticed that the air box connection is loose after getting to work on the car. Took the box off, changed the filter and vacuum hoses but noticed the connection isn’t tight after getting everything back together. I’m not married to the stock box if there is a better solution but just not sure if this connection is a wear item or I’m missing a way to tighten this connection.
Thanks! Attached thumbnail(s) |
914sgofast2 |
Feb 4 2023, 04:30 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I think you need to replace the rubber seal that seals the connection between the air filter box and the throttle body opening. The purpose is to provide an air tight seal at the joint so no dust gets sucked in through the throttle body/air box interface.
Superhawk996 |
Feb 4 2023, 06:17 PM
914 Guru Group: Members Posts: 5,826 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I think you need to replace the rubber seal that seals the connection between the air filter box and the throttle body opening. The purpose is to provide an air tight seal at the joint so no dust gets sucked in through the throttle body/air box interface. (IMG:style_emoticons/default/agree.gif) Tried to find part in PET - it is vague as can be on the air box throttle body for the various engines - no clear pictures or part number |
Lo-Fi Version | Time is now: 18th May 2024 - 04:25 AM |
