Max Tire Width 4 Lug Fuchs?, To roll the wheel well lip or not? |
GeorgeKopf |
Feb 7 2023, 09:15 AM
Member Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
My chassis is at the stage where I have to make a decision on whether or not to roll the wheel well lip. I will be running the 4 lug 2.0 Fuchs (15 x 5.5).
I searched the forums but couldn't find an answer to my exact question. What is the widest tire I can run with and without rolling the wheel well lip? Does it make any difference? I am interested in maximizing traction but I'm not willing to go to flared fenders. Thanks. George |
GeorgeKopf |
Feb 7 2023, 10:55 AM
To provide a little more context.
My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George |
mihai914 |
Feb 7 2023, 12:58 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
To provide a little more context. My chassis is almost ready for paint. If I'm going to roll the wheel well lip, now is the time. Am I correct in my belief that in order for the speedometer to be accurate the total tire diameter needs to be 25.5 inches? Saw this on Pelican. 205/60 = 4.8 inches on the sidewall + 15 = 24.6 inches. 205/65 = 25.4 inches 210/60 = 24.8 inches 210/65 = 25.65 inches I'm assuming that there is no way a 210 tire will fit on a 914 without fender flares. So I guess my question boils down to .... If I roll the wheel well lip, can I put a 205/65, 210/60 or a 210/65 on the car? Thanks. George If you're at this stage of the project, you might as well roll the fenders if you're considering anything over 195/65/15 and if it's not a big expense. The way the body was assembled really dictates what will fit on your car without rubbing. If speedo accuracy is a concern, you can also have the speedo recalibrated to fit your new tires. And most of all, JamesJ is right, threadwear rating is important. A 195 or 185 tire with 180 threadwear is better than a 205 with 600 or 700. Unless you use the car as a daily driver, any tire you'll buy will dry out before wearing out. |
Chris914n6 |
Feb 7 2023, 03:17 PM
Jackstands are my life. Group: Members Posts: 3,307 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
And most of all, JamesJ is right, threadwear rating is important. A 195 or 185 tire with 180 threadwear is better than a 205 with 600 or 700. Unless you use the car as a daily driver, any tire you'll buy will dry out before wearing out. You have it backwards. A 195 or 185 is going to be the high mileage econo car tire size. I have seen 205 in the stickier <400. Something <200 is going to be a 205/50. 205/50-15 is common with track Miatas. |
mihai914 |
Feb 7 2023, 03:34 PM
And most of all, JamesJ is right, threadwear rating is important. A 195 or 185 tire with 180 threadwear is better than a 205 with 600 or 700. Unless you use the car as a daily driver, any tire you'll buy will dry out before wearing out. You have it backwards. A 195 or 185 is going to be the high mileage econo car tire size. I have seen 205 in the stickier <400. Something <200 is going to be a 205/50. 205/50-15 is common with track Miatas. I was implying that something like this: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes Or this: https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes Would be better than a common 205/50 that tire places usually carry in stock. |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:59 AM |
