Testing -6 alternator/regulator in car?, Yep I tried searching but maybe I suck at that... |
campbellcj |
Feb 7 2023, 02:13 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Hi All -
I'm fairly sure my alternator (-6) just crapped-out and want to confirm that's the problem. Very abruptly my dash voltmeter dropped to around 10-11V when running, regardless of revs, vs the normal 13.8 or whatnot. The battery did not seem to be charging, but was just about 5 yrs old so I replaced it, however no change in the voltmeter reading. All wiring and grounds look intact, same as before the issue started. The car starts and runs normally with a charged battery. Is there an easy way to confirm it is or isn't the alternator with the engine still in the car? Thanks! |
Superhawk996 |
Feb 20 2023, 08:09 PM
914 Guru Group: Members Posts: 5,827 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Full field it.
If it makes 14v or more then the alternator is fine. If alternator is good you know you have a bad regulator. If it doesn’t make good voltage you have a bad alternator. It’s that simple. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:25 PM |
