Trailer tires, Time to replace. Suggestions |
Krieger |
Feb 7 2023, 06:51 PM
Advanced Member Group: Members Posts: 4,694 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
So my twin axle 7000 lb. open trailer is 8 years old and the date code on these tires will be 9 years soon. I know I must replace these tires. I completed inspected each tire every time I used the trailer. Maybe around 6-7k miles total. The tires look like they are maybe three years old. I think these were bias ply. They are Hi Run LQ 229 205/75 D 15. I just found these online for $69 each. For all I know Hi Run are crap tires now. Should I just go to COSTCO or Les Schwab? Does anybody have brand recommendations? Radial or bias ply?
Thank you Attached thumbnail(s) |
brant |
Feb 7 2023, 08:27 PM
914 Wizard Group: Members Posts: 11,607 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
You really need trailer rated tires
I believe decent ones are 10 ply You really don’t want a problem when towing That could take out your tow vehicle at the same time Worth correct trailer tires |
Unobtanium-inc |
Feb 7 2023, 08:30 PM
Advanced Member Group: Members Posts: 2,199 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
For years I bought the cheap ones at Tractor Supply, usually already on the rim. BY chance I had to put a set on a trailer to get it home at a tire store. They were Trailer King, and man what a difference. They ran better, longer, and didn't pancake when I loaded the trailer. It was worth the extra money. I ordered a set the last time I replaced them on one of my trailers. They also run cooler. I get them from Simple Tire.
Attached image(s) |
Front yard mechanic |
Feb 7 2023, 08:39 PM
Senior Member Group: Members Posts: 1,153 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
The main thing with those trailer tires is balance them and never run them under inflated. I keep an extra set around
Krieger |
Feb 8 2023, 12:17 AM
Excellent advice guys! Thank you very much!
GregAmy |
Feb 8 2023, 07:21 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
My nice 10k enclosed race car trailer and 32' RV that I don't want to wreck gets the Goodyears. Very good quality tire.
The aluminum open trailer that has 5K capacity and only carries a 914 race car and tire rack gets Walmarts. I inspect them often. Both get replaced every five years. |
914Sixer |
Feb 8 2023, 07:47 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Trailer King RST radial tires is what I am running.
Jamie |
Feb 8 2023, 09:03 AM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
You really need trailer rated tires I believe decent ones are 10 ply You really don’t want a problem when towing That could take out your tow vehicle at the same time Worth correct trailer tires It is definitely poor policy to cheap out on trailer tires. I have many years experience towing big RV's as well as smaller trailers, and always rely on the reduced heat build-up characteristics and flexibility of radial tires rated for trailer use. They are formulated for less degradation from constant UV exposure, but still need to be constantly inspected and replaced on recommended schedule. |
Beach914 |
Feb 8 2023, 09:55 AM
Senior Member Group: Members Posts: 961 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
I just purchased some Trailer King 10 ply 205/75-15's for my Trailer. Went up from previous 7 ply tires. Gotta get it ready for Rennsport in Oct!
brant |
Feb 8 2023, 10:51 AM
I should have added.... the comments above about UV protection are very good ones...
I started using tire covers (they sell for RV's) on my trailer tires about 3 years back. sorta annoying to take them off and put them on repeatedly... but they can only help save your tires and very worth it. |
jd74914 |
Feb 8 2023, 02:00 PM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
You really need trailer rated tires I believe decent ones are 10 ply You really don’t want a problem when towing That could take out your tow vehicle at the same time Worth correct trailer tires It is definitely poor policy to cheap out on trailer tires. I have many years experience towing big RV's as well as smaller trailers, and always rely on the reduced heat build-up characteristics and flexibility of radial tires rated for trailer use. They are formulated for less degradation from constant UV exposure, but still need to be constantly inspected and replaced on recommended schedule. (IMG:style_emoticons/default/agree.gif) 10 ply is ideal. To me, buying crappy trailer tires is like buying crappy tires for a backhoe or other heavy load moving equipment. Saves you money up front, but if you have an issue, particularly while loaded, your life is on the line. |
bossboy302 |
Feb 8 2023, 04:49 PM
Member Group: Members Posts: 73 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
I've run Tow King (?) tires in that size for years. 3000# trailer and 3500-4000# of car/stuff. Very reliable. Les Schwab, because when I travel they're pretty much everywhere. Plus LW has good warranty.
Krieger |
Feb 8 2023, 05:37 PM
I called up Simple Tire and ordered the Trailer King RST tires. they are shipping the tires to the shop that I normally use free of charge. My tire guy liked that brand as well. They had no information as to the date code on the tires. They are allowing me to return the tires free of charge if I felt they were too old. I'd be happy with anything that was made 2022. $315 for a set of 4. Thank you all for your input!
TROJANMAN |
Apr 4 2024, 07:25 PM
Looks nice in pictures......... Group: Members Posts: 5,240 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
I just bought tires. I went with "D" Load range, because I have a dual axle trailer, and the tires are engineered to hold up to 2500# of weight per tire. That's a lot of 914s. (IMG:style_emoticons/default/rolleyes.gif)
6 ply is probably enough, 8 ply is plenty, and 10 ply is for lots of extra stuff. Open or closed trailer should probably be a deciding factor. I was going to buy the cheap walmart ones, because, well, they were cheap. I believe the cheaper ones were load C, which would have been plenty for my application, but I ended up getting Big O Tires to match the Walmart price with a superior tire. Happy Trailering! I love my Air Conditioning on the way to events (IMG:style_emoticons/default/driving.gif) Attached image(s) |
stownsen914 |
Apr 5 2024, 06:47 AM
Senior Member Group: Members Posts: 912 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I should have added.... the comments above about UV protection are very good ones... I started using tire covers (they sell for RV's) on my trailer tires about 3 years back. sorta annoying to take them off and put them on repeatedly... but they can only help save your tires and very worth it. ^^This. I noticed a big difference in the appearance of my trailer spare tire (which is stored inside my trailer) vs the tires on the trailer. My trailer doesn't get a ton of use, so I attributed it to UV exposure. I put covers on for storage now. |
slivel |
Apr 5 2024, 12:07 PM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Having towed race car and horse trailers for more than 24 years, I am a believer in quality trailer rated tires that are sized for your load. Load range D (65 psi) or load range E (80 psi) are what I use.
Additionally, I strongly recommend a TPMS system for your rig. A slow leak will heat up the tire and eventually cause failure. TPMS saved me more than once. They are not terribly expensive and I put sensors on the tow vehicle and the trailer. https://www.amazon.com/Truck-Systems-Techno...ressure-Monitor |
slivel |
Apr 5 2024, 12:09 PM
Having towed race car and horse trailers for more than 24 years, I am a believer in quality trailer rated tires that are sized for your load. Load range D (65 psi) or load range E (80 psi) are what I use. Additionally, I strongly recommend a TPMS system for your rig. A slow leak will heat up the tire and eventually cause failure. TPMS saved me more than once. They are not terribly expensive and I put sensors on the tow vehicle and the trailer. https://www.amazon.com/Truck-Systems-Techno...ressure-Monitor Sorry, I truncated the link and it doesn't work. Just search for tire pressure monitoring systems. |
TROJANMAN |
Apr 5 2024, 02:56 PM
[quote name='slivel' date='Apr 5 2024, 10:09 AM' post='3137975']
[quote name='slivel' post='3137974' date='Apr 5 2024, 11:07 AM'] Having towed race car and horse trailers for more than 24 years, I am a believer in quality trailer rated tires that are sized for your load. Load range D (65 psi) or load range E (80 psi) are what I use. Additionally, I strongly recommend a TPMS system for your rig. A slow leak will heat up the tire and eventually cause failure. TPMS saved me more than once. They are not terribly expensive and I put sensors on the tow vehicle and the trailer. https://www.amazon.com/Truck-Systems-Techno...ressure-Monitor [/quote] Good idea. Did you find any loss of pressure after loaded? curious.... |
slivel |
Apr 5 2024, 05:55 PM
[quote name='TROJANMAN' date='Apr 5 2024, 01:56 PM' post='3137994']
[quote name='slivel' date='Apr 5 2024, 10:09 AM' post='3137975'] [quote name='slivel' post='3137974' date='Apr 5 2024, 11:07 AM'] Having towed race car and horse trailers for more than 24 years, I am a believer in quality trailer rated tires that are sized for your load. Load range D (65 psi) or load range E (80 psi) are what I use. Additionally, I strongly recommend a TPMS system for your rig. A slow leak will heat up the tire and eventually cause failure. TPMS saved me more than once. They are not terribly expensive and I put sensors on the tow vehicle and the trailer. https://www.amazon.com/Truck-Systems-Techno...ressure-Monitor [/quote] Good idea. Did you find any loss of pressure after loaded? curious.... [/quote] No loss of pressure. I have the two external styles - the pass through is more convenient. |
TROJANMAN |
Apr 14 2024, 07:20 AM
For the Record, I installed NATIONAL Road Max ST.
These were D rated. We just finishied a trip through a blizzard and driving (sometimes, by accident) up tp 90 MPH. The tires handled flawlessly, and the trailer was a comfort to tow. They were the recommended tire by Big O (a national chain) |
Lo-Fi Version | Time is now: 20th April 2024 - 09:48 AM |
