> subaru alt. not charging on start up., subaru alt.
jeepguy06
post Feb 15 2023, 04:47 PM
hey all,
so when i start my car i notice that the alt wont put out 13v for a bit after start up.at times i have drove for over 10 mins and it has dropped down to 8 volts before it starts putting out 13v. also feel that the battery is draining down if the car sits longer then a day. so i have to keep it on the charger. when i hooked up all the wires i ran one from battery post to one of the 2 wire terminals and second one it ran up to the charging light. the light has been changed over to a led bulb and also stays on all the time when the car is running. any help would be great.
Thanks
Replies(1 - 3)
davep
post Feb 15 2023, 09:39 PM
914 Historian
This is one bulb where an LED absolutely cannot be used. Just put the old bulb back in.
mjrrti
post Feb 16 2023, 01:49 AM
High Desert Member
QUOTE(jeepguy06 @ Feb 15 2023, 02:47 PM) *
hey all,
Thanks
The bulb is what excites the alternator to charge. You need the draw from the stock bulb to do that. The LED does not draw enough. A burned out bulb will give you the same result.
jeepguy06
post Feb 16 2023, 08:55 AM
ok this makes since that it would want an original bulb set up.
- Lo-Fi Version Time is now: 8th June 2026 - 02:50 PM
