> Transmission and clutch rebuild, Not shifting smooth regardless of clutch
Wew
post Feb 16 2023, 09:33 PM
Hi all,
I did a Dr. Evil transmission rebuild a couple years ago and also put a new flywheel, clutch disc and pressure plate along with a new clutch cable.
Drove the car about 20 miles and everything worked well. A little tough getting it into first but I think I could have adjusted the clutch and addressed that.
Engine was rebuilt, by your truly and was leaking oil so I dropped the motor several times 3x to track down the leak. Pulled heads and piston cylinders and found one of my problems with piston oil ring missing one of two rings that sandwiches the waffle ring.
Fixed problem, albeit 2 years later and engine and transmission are ready for install again.
Now the transmission and clutch are not behaving. Tighten clutch cable and depress clutch pedal to go through gears and it’s like the clutch is not working. I take my foot off the clutch and can still push through the gears with no noticeable difference in the feel or movement. Now I haven’t lined up the shifter to be spot on however there is no difference between clutch pedal pushed all the way down or the cable totally disconnected.
I look at the shift fork and it seems to be frozen or no play.
I remove transmission and clutch and inspect. When I did the trans rebuild I also got the new fork bracket and plastic bushing and whatever else could be replaced. Of course a new throw out bearing as well.
Move fork back and forth everything moves nicely, maybe my flywheel, clutch disc nipple out, facing towards the rear of the car, and pressure plate (pressure plate fingers had some markings on them) weren’t lined up perfectly. I used the plastic alignment tool again and make sure everything is straight on. Put some swepco grease on the nose and spline of the transmission shaft and up she goes back onto the car.
Everything lines up nicely and slide back in without to much trouble.
The clutch fork rests against the housing towards the front of the car and has about a 1/2” of play towards the back.
Cable back on and tightened and no difference. When clutch pedal is depressed the fork moves, but there is no difference in the feel. Role pin is in place.
I have also put a camera in the center tunnel and cables are routed properly and the brackets for the cable guide tubes are in place.
Where have I gone astray (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/confused24.gif)
Wew   Transmission and clutch rebuild   Feb 16 2023, 09:33 PM
Robarabian   Are you testing this on a running engine or just d...   Feb 16 2023, 09:42 PM
Wew   Hi Robar, I am depressing the clutch on a non runn...   Feb 17 2023, 09:23 AM
Jack Standz   " Tighten clutch cable and depress clutch ped...   Feb 17 2023, 10:34 AM
Wew   " Tighten clutch cable and depress clutch pe...   Feb 17 2023, 12:33 PM
Wew   Hi Jack, Yes, clutch feels like it’s not disenga...   Feb 17 2023, 12:13 PM
Wew   This is a picture of the fork in the transmission....   Feb 17 2023, 12:35 PM
Jack Standz   Some more guesses: clutch cable not properly adj...   Feb 17 2023, 12:47 PM
dr914@autoatlanta.com   maybe during the down time, the clutch disc glued ...   Feb 17 2023, 12:51 PM
Steve   The clutch fork should be around half way in the o...   Feb 17 2023, 01:07 PM
Wew   Thanks gents. The oil leak didn’t impact clutch...   Feb 17 2023, 01:15 PM
Wew   After reading Steve’s post I think I need to pul...   Feb 17 2023, 01:19 PM
Wew   After reading Steve’s post I think I need to pul...   Feb 17 2023, 01:36 PM
Wew   Attached are the photos   Feb 17 2023, 01:41 PM
Wew   Maybe my clutch disc is backwards? Can’t think...   Feb 17 2023, 02:28 PM
914werke   So think of the mechanics of the process. Push pe...   Feb 17 2023, 03:03 PM
Wew   Some pics after transmission drop   Feb 17 2023, 03:27 PM
Wew   Looks like clutch disc was on properly. Throw out ...   Feb 17 2023, 03:35 PM
Wew   Thanks for the input Rich. I don’t think my plas...   Feb 17 2023, 04:03 PM
theer   The wear marks on the pressure plate fingers look ...   Feb 17 2023, 04:18 PM
Geezer914   With the car sitting, and the engine not running, ...   Feb 17 2023, 05:34 PM
914werke   I don’t think my plastic bushing and ball we pr...   Feb 17 2023, 05:35 PM
Wew   I don’t think my plastic bushing and ball we p...   Feb 17 2023, 05:50 PM
Wew   Transmission and clutch back in. Off to a social ...   Feb 17 2023, 05:46 PM
- Lo-Fi Version Time is now: 1st July 2025 - 11:44 AM
