Rookie Questions about setting up a 914 for Autocross, Rookie Questions about setting up a 914 for Autocross |
Huck271 |
Feb 19 2023, 05:01 PM
Newbie Group: Members Posts: 3 Joined: 19-February 23 From: The Woodlands, TX Member No.: 27,172 Region Association: Southwest Region |
I am looking at picking up a 914 and turning it into a track/autocross car. My questions are high level. If you can assist with any or all any assistance is appreciated.
Body Fenders - Plan to go wide body to fit larger tires, recommendations/pros/cons ? Metal/fiberglass? Floor Pans - they don't look bad, but I saw somewhere that you can replace them with deeper ones for sitting lower, i'm tall so every inch counts. Braces/stiffing - full cage or something in the rear tied into shock towers and something in the front tied to shock towers roll cage - needed? recommended? custom or weld in off the shelf? Suspension Front Hubs - do you upgrade replace these, someone told me swap with 911 to get 5 lug? Coil Overs at the corners? recommendations? Sway Bars? Torsion Bars? Upgrade rack and pinion? Fuel system Fuel Tank - Assume being a 50 year old car to redo the fuel system and get a fuel cell with integrated fuel pump and braided lines, any recommendations? Transmission Keep or upgrade from a 911 or similar to handle more power? Hoping to get 300+ in the motor Braking If I upgrade to 5 lug, then i assume there is a prefered brake upgrade from a 911 for more stopping power Steering Wheel Its not in the center of the driver seat, have people moved it to be more centered? Dash if I move the steering wheel i assume this gets redone with new gauges etc. Front lights i'm thinking or relocating to the bumper and getting a solid frunk with no holes for lights. Cleaner looking Targa top I would assume you can't race with this on so do people ditch it altogether? Motor swap a 6 or go nuts and do an LS? Thanks, |
Charles Freeborn |
Feb 20 2023, 12:15 PM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
As said, build to whichever rule set that the sanctioning body you'll be competing in uses.
Then, what is your budget? When you've sorted those two, here are some resources. Cage - Autopower is budget friendly. You'll have to add on for your suspension point pickups, but their basic cages are sound. Otherwise there are custom fabricators that can build to any spec you want. If you were in this area I could recommend a few. Brakes / suspension (5 lug, etc) PMB Performance Suspension - Elephant Racing Transmission - California Motorsports Engine - depends on which way you go but for 4 cyl European Motorworks for parts and machining, for a 6 you can't go wrong with a Rothsport built engine, for LS I have no idea.. For us tall guys (i'm 6'4" you'll probably have to go speedster style (no roof) so the main hoop of the cage can be higher than the original roofline / Targa bar. Look up "Ginther 914" and you'll see what I mean. My car is done this way. Yes you can / should race with the top if you choose to keep it. Mine has an ATL Sp 115 fuel cell, external electric pump. |
Huck271 |
Feb 20 2023, 02:03 PM
As said, build to whichever rule set that the sanctioning body you'll be competing in uses. Then, what is your budget? When you've sorted those two, here are some resources. Cage - Autopower is budget friendly. You'll have to add on for your suspension point pickups, but their basic cages are sound. Otherwise there are custom fabricators that can build to any spec you want. If you were in this area I could recommend a few. Brakes / suspension (5 lug, etc) PMB Performance Suspension - Elephant Racing Transmission - California Motorsports Engine - depends on which way you go but for 4 cyl European Motorworks for parts and machining, for a 6 you can't go wrong with a Rothsport built engine, for LS I have no idea.. For us tall guys (i'm 6'4" you'll probably have to go speedster style (no roof) so the main hoop of the cage can be higher than the original roofline / Targa bar. Look up "Ginther 914" and you'll see what I mean. My car is done this way. Yes you can / should race with the top if you choose to keep it. Mine has an ATL Sp 115 fuel cell, external electric pump. Thank you! I'm 6'4 as well. I sat in an empty tub yesterday with the factory seat not bolted to the floor and was suprised i didn't touch the targa top, i imagine i would with a helmet. I also figured the seat could be mounted lower and i have even seen a floor pan with an inch drop in it for extra clearance. I am in the gathering information phase so appreciate the feedback. I was mainly thinking along the lines of autocross or road racing. Still looking for rule books for the different sanctioning bodies and comparing what is available close to me (Houston Tx) |
Charles Freeborn |
Feb 20 2023, 04:51 PM
As said, build to whichever rule set that the sanctioning body you'll be competing in uses. Then, what is your budget? When you've sorted those two, here are some resources. Cage - Autopower is budget friendly. You'll have to add on for your suspension point pickups, but their basic cages are sound. Otherwise there are custom fabricators that can build to any spec you want. If you were in this area I could recommend a few. Brakes / suspension (5 lug, etc) PMB Performance Suspension - Elephant Racing Transmission - California Motorsports Engine - depends on which way you go but for 4 cyl European Motorworks for parts and machining, for a 6 you can't go wrong with a Rothsport built engine, for LS I have no idea.. For us tall guys (i'm 6'4" you'll probably have to go speedster style (no roof) so the main hoop of the cage can be higher than the original roofline / Targa bar. Look up "Ginther 914" and you'll see what I mean. My car is done this way. Yes you can / should race with the top if you choose to keep it. Mine has an ATL Sp 115 fuel cell, external electric pump. Thank you! I'm 6'4 as well. I sat in an empty tub yesterday with the factory seat not bolted to the floor and was suprised i didn't touch the targa top, i imagine i would with a helmet. I also figured the seat could be mounted lower and i have even seen a floor pan with an inch drop in it for extra clearance. I am in the gathering information phase so appreciate the feedback. I was mainly thinking along the lines of autocross or road racing. Still looking for rule books for the different sanctioning bodies and comparing what is available close to me (Houston Tx) In general the 'broomstick" rule is that if you held a broomstick from the top of the bar to the top of the next forward bar or other structural member (A pillar and top of windshield frame don't count) you need 2" clearance between the top of your helmet and the underside of the broomstick. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:20 AM |
