> flare nut wrenches, flex head or not?
914 RZ-1
post Feb 19 2023, 07:59 PM
Porsche Padawan
Has anyone used flex head flare nut wrenches on the brakes? Are they better, worse or no different than non-flex head ones?
I need to buy an 11mm (for the brake line into the caliper) and 8 mm (for the speed bleeders) and thought I would ask before I bought anything.
Thanks!
bkrantz
post Feb 19 2023, 08:13 PM
When it comes to new tools, the right answer is always "both".
Van B
post Feb 19 2023, 08:27 PM
You got a link?
post Feb 19 2023, 08:29 PM
914-6 GT in waiting
I would buy the standard type first. The size of the flex head might get in the way. The standard ones work well.
But I agree, both of them is the right answer.
914 RZ-1
post Feb 19 2023, 10:51 PM
Porsche Padawan
QUOTE(Van B @ Feb 19 2023, 06:27 PM) *
You got a link?
https://www.amazon.com/GEARWRENCH-81910-Pie...sr=1-3&th=1
914 RZ-1
post Feb 19 2023, 10:54 PM
Porsche Padawan
QUOTE(mepstein @ Feb 19 2023, 06:29 PM) *
I'm going back and forth about buying just the two wrenches I need, a standard set or a flex head set. I don't need both! HA!
Has anyone used the flex head set on a 914 brake caliper and found that it works just fine? I think the flex might be too big to fit on the speed bleeder, but has anyone used one?
Van B
post Feb 19 2023, 11:21 PM
Eh… I think those are a bit much. I plan to add a set of crowfoot flare wrenches with the standard wrenches so I can check torques.
BillJ
post Feb 19 2023, 11:29 PM
I have the flex heads. They work fine on my calipers. Been useful too on the master cylinder.
PatMc
post Feb 20 2023, 08:22 AM
I would strongly suggest buying a flare nut wrench that says Snap-On on it…nothing else I’ve used fits and works as well.
914 RZ-1
post Feb 20 2023, 03:18 PM
Porsche Padawan
QUOTE(PatMc @ Feb 20 2023, 06:22 AM) *
I borrowed a neighbor's Snap-On flare nut wrench. It doesn't fit much better than the Craftsman ones I just got.
bkrantz
post Feb 20 2023, 09:36 PM
I got one of these (11 mm). Very handy for fittings in tight spaces. Amazon now seems to sell only a complete set.
https://www.amazon.com/【LOSCHEN】Open-Fl...C255&sr=1-2
PatMc
post Feb 20 2023, 10:16 PM
QUOTE(914 RZ-1 @ Feb 20 2023, 04:18 PM) *
When you use them every day you'll find that the Snap-on just works...it's a rare occasion where a tube nut becomes damaged. My 11mm gets daily use on brake lines....cannot remember the last time a tube nut with an 11mm hex sustained damage due to the tool.
I recently spread my somewhat rarely used Craftsman 3/8" flare nut wrench when I was working on a crossover pipe on a set of Ford Mustang calipers....Snap on guy was nowhere to be found so I ordered a Proto from McMaster...relatively top shelf brand IMO...it's garbage.
Ordered a Snap-On and all is well again.
- Lo-Fi Version Time is now: 11th July 2025 - 10:51 AM
