tshih914 |
Member ![]() ![]() Group: Members Posts: 79 Joined: 17-July 05 From: central NJ Member No.: 4,426 ![]() |
My 1.8L 914-4 with stock Bosch L?-Jetronic FI after being stored several years started to develop a hard to start problem. When finally started would stall when I give the gas pedal any input to raise the revs. I suspect there was some kind of intake air leak and while fiddling around had a backfire which blew the AF meter which I had Pelicanparts repaired. After replacing the fuel lines with the stainless ones from Tangerine Racing and flushing out the fuel system with Techron the engine started to run normally for a short time. Now the engine can be started and fast idles at 3000 rpm but again any input to rev up the engine results in stalling. The idle adjustment screw at the base of the throttle housing is fully closed. Any suggestions on how to fix?
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Whatever you have back there by the batter near where the decel valve should be is not the correct part. If that thing is opening at idle, it will surely cause a high idle.
Edit: here is a thread of mine about the decel valve. http://www.914world.com/bbs2/index.php?s=&...t&p=2956383 Leave the Aux Air Regulator/Valve alone for now as it should be open until the engine is warm. But if what I’m seeing back there on your second picture is the AAV setup, its a hot mess and probably a big part of your problem. |
Lo-Fi Version | Time is now: 18th July 2025 - 06:50 PM |
