1974 1.8L engine fast idle then stalls, Fuel injection issues |
tshih914 |
Feb 19 2023, 11:45 PM
Member Group: Members Posts: 79 Joined: 17-July 05 From: central NJ Member No.: 4,426 |
My 1.8L 914-4 with stock Bosch L?-Jetronic FI after being stored several years started to develop a hard to start problem. When finally started would stall when I give the gas pedal any input to raise the revs. I suspect there was some kind of intake air leak and while fiddling around had a backfire which blew the AF meter which I had Pelicanparts repaired. After replacing the fuel lines with the stainless ones from Tangerine Racing and flushing out the fuel system with Techron the engine started to run normally for a short time. Now the engine can be started and fast idles at 3000 rpm but again any input to rev up the engine results in stalling. The idle adjustment screw at the base of the throttle housing is fully closed. Any suggestions on how to fix?
Van B |
Feb 28 2023, 08:53 PM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Thats too low IMO. I posted the link to my thread on post #29 on your thread here.
Lo-Fi Version | Time is now: 18th May 2024 - 10:25 AM |
