> New-to-Me 74 1.8l_Where to start on electrical issues
rcautox
post Feb 20 2023, 06:47 PM
Hi all,
I've been scouring 914 world for help on getting a new-to-me '74 1.8l running. I've reviewed Auto Atlanta's informative video on the 914 fuse & wiring and I think I follow the gist but may have missed things. I've also studied the simplified diagrams on Pelican Parts which have been helpful to understand the 914 layout.
What I've done:
1. new battery
2. new ground strap straight to the transmission bolt in the rear of the engine bay
3. cleaned battery connections
4. cleaned the fuse panel
When I turn the key the only thing I can see working is the marker lights and the clock. So no fuel pump, no start, etc.
Can you all point me to a few areas to tackle first to determine the culprit(s)?
rcautox   New-to-Me 74 1.8l_Where to start on electrical issues   Feb 20 2023, 06:47 PM
SteveL   Seat Belt Interlock ?   Feb 20 2023, 06:49 PM
Van B   Carbs, FI?   Feb 20 2023, 08:14 PM
Dave_Darling   Start at the wiring diagrams. Your Haynes manual ...   Feb 21 2023, 03:32 AM
930cabman   :wttc: Was the car running when you purchased he...   Feb 21 2023, 07:15 AM
rcautox   Regarding seat belt bypass-I pull the passenger se...   Feb 21 2023, 11:25 AM
bdstone914   Regarding seat belt bypass-I pull the passenger s...   Feb 21 2023, 12:45 PM
wonkipop   Regarding seat belt bypass-I pull the passenger s...   Feb 21 2023, 01:47 PM
Van B   So, two things to check: 1.) With the key on, pus...   Feb 21 2023, 12:29 PM
rcautox   Thank you for the detailed suggestions. I gently p...   Feb 21 2023, 11:50 PM
wonkipop   Thank you for the detailed suggestions. I gently ...   Feb 22 2023, 04:46 PM
Van B   Thank you for the detailed suggestions. I gently ...   Feb 22 2023, 08:37 PM
StarBear   On 1.8s, don’t forget the unique dual relay and ...   Feb 22 2023, 08:11 AM
rcautox   Fuel pump is in the front. I pulled the tank, clea...   Feb 22 2023, 10:56 PM
wonkipop   Fuel pump is in the front. I pulled the tank, cle...   Feb 23 2023, 02:10 PM
Dave_Darling   The yellow wire should be getting power only while...   Feb 23 2023, 12:53 AM
rcautox   In the starting position I do not have power in th...   Feb 25 2023, 02:53 PM
porschetub   In the starting position I do not have power in t...   Feb 26 2023, 01:19 PM
Dave_Darling   In the starting position I do not have power in t...   Feb 26 2023, 05:10 PM
r_towle   You have power, key in start position, to the yell...   Feb 26 2023, 05:30 PM
rcautox   I removed the male spade connector and tested each...   Feb 26 2023, 07:59 PM
Van B   Yeah don’t forget they are plugged like that bec...   Feb 26 2023, 08:10 PM
Dave_Darling   The whole idea is that the yellow wire carries the...   Feb 26 2023, 09:25 PM
rcautox   Thank you for the help! I have power at pin 1 ...   Feb 28 2023, 12:44 PM
Dave_Darling   Sounds like either a bad connection there, or mayb...   Mar 1 2023, 08:38 PM
rcautox   I pulled the cover off the 12 pit connector, gentl...   Mar 3 2023, 01:06 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 05:29 PM
