Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
SOLD: Pair of 1.7 and 1.8 (I think) stainless steel heat exchangers.
Please read: I don't know the story of these but I am not sure the ends at the heads are correct (pros, please chime in). (IMG:style_emoticons/default/dry.gif) I guess someone could weld on the proper ones. Pictures are pretty descriptive and I can obviously take more. I was surprised to see that the tubes are 1 1/2", which is the same as my 2liter SS heat exchangers. (IMG:style_emoticons/default/smile.gif) Price: Pick up welcome in Claremont, CA, or can meet in Pasadena on certain weekdays. Could also ship at buyers expense. Thank you for looking! (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() [attachmentid=868296 ![]() ![]() ![]() ![]() |
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
This appears to be a very good deal!! The ends are not correct as far as I know. But the factory ends would be easy enough replicate/fabricate and weld on I assume.
These shouldn’t take long to sell. GLWTS |
Montreal914 |
Thank you (IMG:style_emoticons/default/smile.gif)
Priced accordingly base on uncertain head ends. (IMG:style_emoticons/default/confused24.gif) |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,293 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Someone has cut off the cast ends from a set of OE 1.7L HE's & grafted them on.
Not sure why but I do recall the ears on the SSI are prone to tearing free if you over torque them as the SS pipe is thin in contrast to OE. You may be able to simple cut them clean & use a set of Chris's Stub pipes? |
Montreal914 |
Happy Friday!
(IMG:style_emoticons/default/icon_bump.gif) Open to offers! (IMG:style_emoticons/default/beerchug.gif) |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,094 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Someone has cut off the cast ends from a set of OE 1.7L HE's & grafted them on. Not sure why but I do recall the ears on the SSI are prone to tearing free if you over torque them as the SS pipe is thin in contrast to OE. You may be able to simple cut them clean & use a set of Chris's Stub pipes? Those are not stock 1.7 ends, they appear to be for square port late bus heads. Stock exchangers/oval ports have the nut flanges recessed. |
Montreal914 |
Thank you for the info! (IMG:style_emoticons/default/smile.gif)
I did mention in the original post that something was unknown at the head ends. That is why I am open to offers! (IMG:style_emoticons/default/beerchug.gif) |
Montreal914 |
Friday bump (IMG:style_emoticons/default/icon_bump.gif)
How about $100? (IMG:style_emoticons/default/confused24.gif) |
Montreal914 |
Sold and shipped! (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 4th July 2025 - 05:05 AM |
