Front Brake Issue, 914 Pulls right when stopping |
PDXBob |
Mar 4 2023, 07:14 PM
Newbie Group: Members Posts: 32 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest |
Hi All,
I just finished putting on rebuilt rear brake calipers done by PMB. Also, new braided steel brake lines and set of new Textar pads on all 4 wheels (1975 914). I took it out to do the “bedding” break-in process and I noticed it was pulling to the right. So, (after doing cool down slow driving)when I got home I checked temperature of rotors. Both back rotors were about 125 degrees. However front right was about 240 degrees. BUT front left was only about 85 degrees. To a novice like me seems like front left is not working. Any suggestions on diagnostic procedures or what to check out. Thanks PDXBob |
ndfrigi |
Mar 4 2023, 09:22 PM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
When you bled the left front, does it push brake fluid?
You can also try to jack the front and someone will turn the wheel and one person inside to push the brake. To check if left wheel will brake and compare to right side. |
Lo-Fi Version | Time is now: 16th May 2024 - 10:05 PM |
