Front Brake Issue, 914 Pulls right when stopping |
PDXBob |
Mar 4 2023, 07:14 PM
Newbie Group: Members Posts: 32 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest |
Hi All,
I just finished putting on rebuilt rear brake calipers done by PMB. Also, new braided steel brake lines and set of new Textar pads on all 4 wheels (1975 914). I took it out to do the “bedding” break-in process and I noticed it was pulling to the right. So, (after doing cool down slow driving)when I got home I checked temperature of rotors. Both back rotors were about 125 degrees. However front right was about 240 degrees. BUT front left was only about 85 degrees. To a novice like me seems like front left is not working. Any suggestions on diagnostic procedures or what to check out. Thanks PDXBob |
Eric_Shea |
Mar 6 2023, 09:15 AM
Hey Bob,
Are the soft lines new? If not then I would recommend checking those. https://pmbperformance.com/pages/frequently...-questions-faqs About mid-way down on our FAQ page you'll see that old soft lines lines can swell from the inside. This often retains pressure on your front right (in your case). It will then lock up and pull to the right when you apply nominal pressure. It often drags as well then causing the heating issue you're having. My rule is, if you don't know when your soft lines were replaced... replace them. Otherwise, every 10 years. Hope that helps... give us a call if you have any other issues. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:32 AM |
