Dumbest Thing |
Dumbest Thing |
bkrantz |
Mar 11 2023, 09:02 PM
914 Guru Group: Members Posts: 7,756 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I know we have threads about PO stupidity, but how about the dumbest 914 thing you have done?
I will start with a, ahem, senior moment I had today. When I tried to add oil after my recent engine re-installation, it would not go in. Short version: I forgot to remove the paper towels I had folded up and tucked into the breather recess while the engine was out of the car, to keep anything from falling into the case. I still can't believe that I installed the breather and did not see and remove paper towels. Attached thumbnail(s) |
76-914 |
Mar 12 2023, 09:15 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Last week my turn signals quit working on a short drive to the store. When I came home I checked fuse 7 and it was good but since it had the fuse panel upgrade - done by others - I checked them all to no avail. Well crap, it was time to dive into it. Removed the lower knee pad dropped the fuse panel, Emergency flasher switch, headlamp switch & Fog Lamp switch - can't remove just the one by itself. The Emergency Flashers worked but I tested the flasher relay anyway and of course it was good. I even opened it up to check the contact points. Next I checked for continuity between 48 & L/ R on the Emergency Flasher switch to confirm that the Turn Signal switch was good and yes it indicated so. Being the optimistic idiot I've become I installed a spare switch and still No Worky! Not trusting myself - I'm sure the neighbors think I'm giving my wife the business as I'm always verbally abusing myself in the garage - I removed the Turn Signal switch in hopes that I would find a dropped pin, etc. Everything looked OK but I changed it out with a NOS one in my stash and that didn't correct anything either. (IMG:style_emoticons/default/headbang.gif) Now at wits end I decided to check the true signal lamps and found the loose spade connecter on the left Tail Lamp bucket. The 1st damned thing I should have checked but NOOOOOOOO! I had to piss off a few hours instead of checking the easiest & most common failure point in that system. (IMG:style_emoticons/default/fyou1.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 02:23 PM |
