Dumbest Thing |
Dumbest Thing |
bkrantz |
Mar 11 2023, 09:02 PM
914 Guru Group: Members Posts: 7,736 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I know we have threads about PO stupidity, but how about the dumbest 914 thing you have done?
I will start with a, ahem, senior moment I had today. When I tried to add oil after my recent engine re-installation, it would not go in. Short version: I forgot to remove the paper towels I had folded up and tucked into the breather recess while the engine was out of the car, to keep anything from falling into the case. I still can't believe that I installed the breather and did not see and remove paper towels. Attached thumbnail(s) |
jhynesrockmtn |
Mar 12 2023, 09:20 PM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I had pulled the engine on my 70 to fix a bunch of leaks and freshen things up. The trans, exhaust and bottom of the engine were caked with oil and trans fluid. I cleaned everything up including the heat exchangers. The good news, the leaks were solved. The bad news, I didn't clean the inside of the heat exchangers which now had a combination of cleaning solution mixed with greasy gunk in them. I had to pull the heater parts back off and using a hose, towels, and stuff to push and pull the towels I managed to clean the inside good enough without pulling them off the car.
Lo-Fi Version | Time is now: 28th April 2024 - 06:03 AM |
