Dumbest Thing |
Dumbest Thing |
bkrantz |
Mar 11 2023, 09:02 PM
914 Guru Group: Members Posts: 7,735 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I know we have threads about PO stupidity, but how about the dumbest 914 thing you have done?
I will start with a, ahem, senior moment I had today. When I tried to add oil after my recent engine re-installation, it would not go in. Short version: I forgot to remove the paper towels I had folded up and tucked into the breather recess while the engine was out of the car, to keep anything from falling into the case. I still can't believe that I installed the breather and did not see and remove paper towels. Attached thumbnail(s) |
technicalninja |
Mar 16 2023, 10:11 AM
Senior Member Group: Members Posts: 1,154 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Trusting the machine shop...
I once built a 74 Fiat 1.8L Spider motor that I didn't verify the bearing clearances when returned from the machine shop. This was from the best machine shop I've ever used. I had assembled multiple motors that they machined, went through all of the bearing clearance checks on the previous motors, and never had a problem. I trusted them and assembled the Fiat (my own car, Thank God!) in record time. Built, installed, and tuned in less than 5 hours. FAST AS SHIT. It lasted 60 miles... Crank main journals had been ground an EXTRA .005" so they were .025 under instead of .020. Wiped out an early Fiat spider crank which had enough different than the later ones that I had to find the right critter. Took 6 weeks to find one. I am an anal-retentive pin head regarding machine work that I have not done myself now. And I've stopped trying to do stuff FAST anymore. Just leads to problems down the road That was back in 1987. The ONLY saving grace was that it was my personal car. Had it been a customer car I'd have been really screwed... |
Superhawk996 |
Mar 16 2023, 11:13 AM
914 Guru Group: Members Posts: 5,749 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I trusted them and assembled the Fiat (my own car, Thank God!) in record time. First might have been owning a Fiat (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 27th April 2024 - 08:00 AM |
