Dumbest Thing |
Dumbest Thing |
bkrantz |
Mar 11 2023, 09:02 PM
914 Guru Group: Members Posts: 7,736 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I know we have threads about PO stupidity, but how about the dumbest 914 thing you have done?
I will start with a, ahem, senior moment I had today. When I tried to add oil after my recent engine re-installation, it would not go in. Short version: I forgot to remove the paper towels I had folded up and tucked into the breather recess while the engine was out of the car, to keep anything from falling into the case. I still can't believe that I installed the breather and did not see and remove paper towels. Attached thumbnail(s) |
relentless |
Mar 13 2023, 12:58 PM
Member Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
I don't know if it's the dumbest thing I've ever done, but here is *one* that ranks up there. When in my 20's (long ago) I bought a sound system for my 914 to replace the 8 track player. The new system had a huge amp, and I proceeded to mount it in the cabin on the vertical area in front of where the passenger legs go.
I drilled my first hole through the metal and right on through the gas tank. I pulled out the bit and watched gas start to squirt out the hole. It looked just like someone peeing, and of course the tank was full. I panicked and forgot to put a container down to catch the gas. By the time the tank was out several gallons of high test covered the floor. Every time I drove the car after that the faint odor of gasoline reminded me what a dumbass I was. |
jfort |
Mar 16 2023, 03:04 PM
Senior Member Group: Members Posts: 1,134 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I don't know if it's the dumbest thing I've ever done, but here is *one* that ranks up there. When in my 20's (long ago) I bought a sound system for my 914 to replace the 8 track player. The new system had a huge amp, and I proceeded to mount it in the cabin on the vertical area in front of where the passenger legs go. I drilled my first hole through the metal and right on through the gas tank. I pulled out the bit and watched gas start to squirt out the hole. It looked just like someone peeing, and of course the tank was full. I panicked and forgot to put a container down to catch the gas. By the time the tank was out several gallons of high test covered the floor. Every time I drove the car after that the faint odor of gasoline reminded me what a dumbass I was. Your story reminds me. I was helping my mechanic friend put in a rebuilt 911 engine into an old 911. Wouldn't start. Wasn't getting fuel. We worked and worked to eliminate variables. Finally, we noticed a puddle under the car. The car owner, while mounting seat belts, had drilled through the fuel line in the tunnel. |
Lo-Fi Version | Time is now: 27th April 2024 - 09:59 PM |
