1976 Is it a 49 state or Cali car? |
gnomefabtech |
Mar 13 2023, 06:25 PM
Member Group: Members Posts: 96 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Car came from Nevada but I can't tell if it was originally a California car. It still has injection but doesn't have a cat or smog pump. Doesn't look like it ever had either but I'm wondering since I'm going to try and register it here in California. Thanks in advance!!
Here is the Vin: |
gnomefabtech |
Mar 16 2023, 07:24 PM
If you live in CA DO NOT purchase a 76 914 I am going through hell to get mine smog. I would find another year 914 but I have owned mine since the 80s. As far as I know the key is that if it's a 49 state model than I don't need a cat and the restrictive exhaust that goes with it. Still need the smog pump though. Someone correct me if I'm wrong on this. As far as I know this car is a Nevada native and I'll be the first to bring it into Ca.. |
JORACER#40 |
Mar 16 2023, 08:29 PM
Newbie Group: Members Posts: 11 Joined: 27-October 20 From: San Diego Member No.: 24,815 Region Association: Southern California |
If you live in CA DO NOT purchase a 76 914 I am going through hell to get mine smog. I would find another year 914 but I have owned mine since the 80s. As far as I know the key is that if it's a 49 state model than I don't need a cat and the restrictive exhaust that goes with it. Still need the smog pump though. Someone correct me if I'm wrong on this. As far as I know this car is a Nevada native and I'll be the first to bring it into Ca.. The Smog Pump is the is the most difficult to deal with. first the heads must have threaded holes into the each exhaust port only on 75 76. Next the pump brackets and pully usually have been removed along with the EGR. I think all 76 were built in 75 form the left over parts from the 75 run. Even if you get all the parts next is getting the 50 year old FI and ignition to work perfectly for the test. it is hit and miss. I had it down to a science until I didn't. Now I am replacing all the parts I know are on the edge of spec. It is costing me more to fix my FI then to purchase an aftermarket FI which would do a much better job at reducing bad emissions. Sorry for being a downer but I have not been able to drive my 914 for a while just because I can not pass smog. |
Lo-Fi Version | Time is now: 5th May 2024 - 10:54 AM |
