Nate W |
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-February 21 From: Oceanside, Ca Member No.: 25,250 Region Association: Southern California ![]() ![]() |
I need to install my dash and also my windshield. Is there any big advantage to installing one first? I have the windshield to dash seal from 914 rubber, they say it can go in after dash and windshield are in. Any thoughts or advice?
Thanks Nate |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,379 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Dash first would be my suggestion. (IMG:style_emoticons/default/beerchug.gif)
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,427 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
I agree. Easy to get the dash in and adjusted. I did the windshield as the very last thing in my build.
Nate W |
That makes sense. Thanks to both of you for the help
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,736 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
If you're installing new vinyl and foam pad on top of the dash you'd better do that before the windshield. Mark's dash to windshield gasket fits easily after the windshield is installed but check that metal rim it clamps to for straightness and bends before you install the windshield.
Lo-Fi Version | Time is now: 8th July 2025 - 10:56 AM |
