Help Installing Rear Sway Bar Drop Link Bushings |
Tom1394racing |
Mar 16 2023, 01:34 PM
Member Group: Members Posts: 289 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
I need some advice. I have been trying to install the white plastic rear sway bar bushings that I purchased from PMB into the dop links with zero success. I read all the posts on boiling the bushings and lubricating them generously with dish soap. I followed these and used my bench vise to try to press the bushings into the drop link but the bushings just seem too big and always tear when forced in. The one in the photo that I managed to install is torn in the middle.
I have installed many plastic bushings successfully in the past on my 911 projects, but these bushings just seem to be too big. My 911 experience has taught me that often aftermarket parts do not fit and that it is may be necessary to switch to a different supplier. Has anyone installed these successfully in the recent past? Which suppliers have bushings that will fit the drop links? |
DRPHIL914 |
Mar 16 2023, 01:51 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
first time is hard with new bushings. yes boiling in water can help, with some lube , lst time i used a large vice grip or c-clamp to squeeze it on the sway bar and on the lower connection on the shock retaining bolt i think i just used a 2x4 as a lever to push it on.
porschetub |
Mar 16 2023, 02:32 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
first time is hard with new bushings. yes boiling in water can help, with some lube , lst time i used a large vice grip or c-clamp to squeeze it on the sway bar and on the lower connection on the shock retaining bolt i think i just used a 2x4 as a lever to push it on. (IMG:style_emoticons/default/agree.gif) exactly what I did,used the biggest "C" clamp I had . |
Lo-Fi Version | Time is now: 26th May 2024 - 08:56 AM |
