| gnomefabtech |
Mar 18 2023, 07:45 PM
Member ![]() ![]() Group: Members Posts: 154 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Getting a 76 road worthy in Cali (IMG:style_emoticons/default/lol-2.gif) so I need a smog pump and all the tubes etc..
Let me know what you have. Thanks |
| brant |
Mar 19 2023, 07:09 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,276 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I’ve got the pump and hard lines
Will get some photos for you |
| brant |
Mar 19 2023, 08:02 AM
lots of pictures
| technicalninja |
Mar 19 2023, 09:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Boy, am I glad I don't have to use that stuff on my 75 Federal spec car...
That is the first time I've seen ND (Nippon Denso) and Bosch share a parts sticker. Proves the OEMs will sleep with anyone... That will be a rotary vane pump. I'd take that apart, grease the bearings and clean up the cases and the internal parts before I put that back into service. Parts for that pump might be "hen's teeth" to acquire. The bearings will be able to be purchased from a bearing supply using the numbers on the bearings/seals. |
| burton73 |
Mar 19 2023, 11:34 AM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,083 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
It may be me looking at this, but the sacrificial rubber part looks like it's broken on this part
I had a 76 car and when the pump froze it broke this sacrificial rubber part this is the part that connects to the crank. If I'm remembering correctly the part has a metal plate on the end where you bolt up the 3 bolts. Best Bob B ![]() |
| brant |
Mar 26 2023, 10:02 AM
It may be me looking at this, but the sacrificial rubber part looks like it's broken on this part I had a 76 car and when the pump froze it broke this sacrificial rubber part this is the part that connects to the crank. If I'm remembering correctly the part has a metal plate on the end where you bolt up the 3 bolts. Best Bob B ![]() It’s starting to come apart Not separated yet. But needs the repair that all of them need these days Still pretty complete system with mounting brackets/hardware Never heard back from original poster Plan to start a separate add and list this soon if anyone is looking |
| gnomefabtech |
Mar 26 2023, 05:46 PM
I think I might be able to get away without adding this stuff. Stand by.
| ssuperflyoldguy |
Mar 26 2023, 09:28 PM
Member ![]() ![]() Group: Members Posts: 190 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
I believe I have most of the stuff, gotta start pulling it out. My spider is good, I remember losing one on my 76 bus and it was impossible to locate one 30yrs ago
| Super90 |
Mar 27 2023, 03:14 AM
Newbie ![]() Group: Members Posts: 13 Joined: 25-November 10 From: GA Member No.: 12,423 Region Association: South East States |
I have a 75 CA Spec and need the sample pipe that runs from the egr valve you have pictured with the square flange to the muffler area port. Its sort of L shaped, has a welded tab to bolt it to muffler, and 2 bolt square ports at each end. Any help anyone?
![]() Thanks, George |
Lo-Fi Version | Time is now: 18th September 2026 - 02:36 AM |
