gnomefabtech |
Member ![]() ![]() Group: Members Posts: 152 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None ![]() |
Getting a 76 road worthy in Cali (IMG:style_emoticons/default/lol-2.gif) so I need a smog pump and all the tubes etc..
Let me know what you have. Thanks |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,005 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I’ve got the pump and hard lines
Will get some photos for you |
brant |
lots of pictures
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Boy, am I glad I don't have to use that stuff on my 75 Federal spec car...
That is the first time I've seen ND (Nippon Denso) and Bosch share a parts sticker. Proves the OEMs will sleep with anyone... That will be a rotary vane pump. I'd take that apart, grease the bearings and clean up the cases and the internal parts before I put that back into service. Parts for that pump might be "hen's teeth" to acquire. The bearings will be able to be purchased from a bearing supply using the numbers on the bearings/seals. |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,848 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
It may be me looking at this, but the sacrificial rubber part looks like it's broken on this part
I had a 76 car and when the pump froze it broke this sacrificial rubber part this is the part that connects to the crank. If I'm remembering correctly the part has a metal plate on the end where you bolt up the 3 bolts. Best Bob B ![]() |
brant |
It may be me looking at this, but the sacrificial rubber part looks like it's broken on this part I had a 76 car and when the pump froze it broke this sacrificial rubber part this is the part that connects to the crank. If I'm remembering correctly the part has a metal plate on the end where you bolt up the 3 bolts. Best Bob B ![]() It’s starting to come apart Not separated yet. But needs the repair that all of them need these days Still pretty complete system with mounting brackets/hardware Never heard back from original poster Plan to start a separate add and list this soon if anyone is looking |
gnomefabtech |
I think I might be able to get away without adding this stuff. Stand by.
ssuperflyoldguy |
Member ![]() ![]() Group: Members Posts: 186 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None ![]() |
I believe I have most of the stuff, gotta start pulling it out. My spider is good, I remember losing one on my 76 bus and it was impossible to locate one 30yrs ago
Super90 |
Newbie ![]() Group: Members Posts: 13 Joined: 25-November 10 From: GA Member No.: 12,423 Region Association: South East States ![]() |
I have a 75 CA Spec and need the sample pipe that runs from the egr valve you have pictured with the square flange to the muffler area port. Its sort of L shaped, has a welded tab to bolt it to muffler, and 2 bolt square ports at each end. Any help anyone?
![]() Thanks, George |
Lo-Fi Version | Time is now: 30th June 2025 - 08:02 PM |
