Having trouble with a spare parts car side window, another member would like to buy it |
Type 47 |
Mar 20 2023, 03:03 PM
Senior Member Group: Members Posts: 780 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
I have a right hand door window that another forum member has been waiting patiently for. I noticed some kind of fog like substance on it and I can't get it off.
It looks like it might have been some overspray from some previous bodywork, but I can't get it to come clean. It's not a fog in the glass. it is on the outside, side and it also won't scape off with a razorblade. |
914Sixer |
Mar 20 2023, 03:49 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Did you try lacquer thinner?
Cairo94507 |
Mar 20 2023, 04:08 PM
Michael Group: Members Posts: 9,719 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Is it possible someone media blasted it? I have always used clay (like claying a paint surface) and that works most of the time. If not, I use 0000 steel wool with generous amounts of window cleaner for lubrication. I also use a light touch.
Type 47 |
Mar 20 2023, 09:30 PM
Type 47 |
Mar 20 2023, 09:35 PM
Is it possible someone media blasted it? I have always used clay (like claying a paint surface) and that works most of the time. If not, I use 0000 steel wool with generous amounts of window cleaner for lubrication. I also use a light touch. nice, thanks for the advice. The razor reacts to it but doesn't move it. It doesn't look like it got inadvertently sand blasted and etched. I'll try to be gentle with the steel wool. |
Lo-Fi Version | Time is now: 29th April 2024 - 04:08 AM |
