OT neighbor needed a Favor, New timing belts |
rfinegan |
Mar 21 2023, 06:06 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
mb911 |
Apr 4 2023, 06:00 AM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Not done a clutch yet in any of our 944s but pulled the transaxles that is about 30 minutes . The TT can’t be that bad is it? I find the timing belts are pretty straightforward the balance shaft belt needs to be looser than you expect. I find in general the 944s to be pretty easy to work on. We have an 85.5 and an 88 and both run nicely
brubou |
Apr 4 2023, 12:25 PM
Bruce Bouchard Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region |
Not done a clutch yet in any of our 944s but pulled the transaxles that is about 30 minutes . The TT can’t be that bad is it? I find the timing belts are pretty straightforward the balance shaft belt needs to be looser than you expect. I find in general the 944s to be pretty easy to work on. We have an 85.5 and an 88 and both run nicely Can confirm on the balance shaft belts needing to be looser than you think, I set mine to spec and it whined like a supercharger, I went incrementally looser until the whine went away. |
porschetub |
Apr 4 2023, 02:01 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Not done a clutch yet in any of our 944s but pulled the transaxles that is about 30 minutes . The TT can’t be that bad is it? I find the timing belts are pretty straightforward the balance shaft belt needs to be looser than you expect. I find in general the 944s to be pretty easy to work on. We have an 85.5 and an 88 and both run nicely Can confirm on the balance shaft belts needing to be looser than you think, I set mine to spec and it whined like a supercharger, I went incrementally looser until the whine went away. Yes correct,most don't have the tension gauge but set my timing belt with the twist method which worked fine and only needed small tighten after a test drive ,the balance shaft belt was adjusted as described above . Clutch parts are rather expensive but I was super lucky as the rubber centre disk and plate were in good condition ,my throw out bearing was good but running dry (ish) so I repacked it ,however I did overhaul the slave cylinder however with new cups and boot. I was well pleased with the clutch but it only had 123,000 kms on it when I transplanted to a 2.7 motor . |
Lo-Fi Version | Time is now: 18th May 2024 - 03:26 AM |
