OT neighbor needed a Favor, New timing belts |
Mikey914 |
Apr 5 2023, 11:36 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Had a 951 with a manual boost controller. After setting the pressure in the heat of the day, the next morning it was easy to hit 28. 20 was the happy spot. Changed out the head gasket a few times. The belt was the easy part. Do change out all the bearings.
However, the clutch is its own special hell. |
gandalf_025 |
Apr 6 2023, 08:58 AM
Senior Member Group: Members Posts: 1,451 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
I mentioned before that the shop I used to help out at, just outside Boston, had a group of 6 guys with 944 Turbo's that all bought chips for the computers and had them installed there. Within 3 months, all 6 had come in for new clutches.
I had the shop owner wait till the 1 day a week I was going to be there and I'd start the disassembly for him and get as far as I could that day and the next morning he would pick up where I left off and complete the job.. It was a long time ago.. But doing 6 in a row made me not want to go near one again.. |
Jack Standz |
Apr 6 2023, 03:45 PM
Member Group: Members Posts: 272 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Arnnworx.com makes a tensioning tool that costs about 1/10th the factory tool.
On a 944, guessing you got the tension right on the timing belt isn't a good idea. Yes, it's another special tool you won't use that often (although it works on the balance shaft belt too). But, who doesn't like tools? Get the tool. Use it. While you're in there, inspect (or probably should just plan on replacing) the rollers and inspect the water pump. Replace any if even slightly suspect. The 968 has a hydraulic timing belt tensioner, so the tensioning tool isn't needed except for the balance shaft belt. They also changed things so the clutch is a lot easier to replace than the 944s. And, of course there's another special tool available for replacing the RMS while you're in there replacing the clutch. |
brubou |
Apr 6 2023, 03:50 PM
Bruce Bouchard Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region |
Arnnworx.com makes a tensioning tool that costs about 1/10th the factory tool. On a 944, guessing you got the tension right on the timing belt isn't a good idea. Yes, it's another special tool you won't use that often (although it works on the balance shaft belt too). But, who doesn't like tools? Get the tool. Use it. While you're in there, inspect (or probably should just plan on replacing) the rollers and inspect the water pump. Replace any if even slightly suspect. The 968 has a hydraulic timing belt tensioner, so the tensioning tool isn't needed except for the balance shaft belt. They also changed things so the clutch is a lot easier to replace than the 944s. And, of course there's another special tool available for replacing the RMS while you're in there replacing the clutch. I have and used the tool. It was still too tight for the balance shaft belt. |
Mikey914 |
Apr 6 2023, 07:58 PM
Got pretty good at setting the tension. Start a little heavy. You will hear the wurr, like a supercharger. Back it off until it just stops. Got over 80,000 miles on it did this 3 times.
No tool really needed. |
Jack Standz |
Apr 7 2023, 02:54 AM
So, yes i believe the older version may need recalibration from time-to-time. The newest version of the tensioning tool comes with a way to calibrate it before you use it.
Of course, your car, you do what you want with it. So, maybe it's just me, but I actually use feeler gauges when I set valve lash. (IMG:style_emoticons/default/smile.gif) |
mb911 |
Apr 7 2023, 06:29 AM
914 Guru Group: Members Posts: 6,820 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
No tool for me. Belt twist works. The 928s can be more complicated but I opted for the porken tensioner update so it makes it easy.
Lo-Fi Version | Time is now: 4th May 2024 - 02:27 AM |
